Satnogs not defined in gnu adio
After building gr-satnogs from source and opening one of the example flowgraphs there’s an issue with doppler compensation. I get this error: Value “satnogs.rigctl_doppler_correction.make(rx_freq, Hamlib.RIG_MODEL_NETRIGCTL)” cannot be evaluated: name ‘satnogs’ is not defined
I have Hamlib installed, and import Hamlib works perfectly
Has anybody dealt with a similar issue?
Hello
Did you make install gr-satnogs? If yes maybe you need to run ldconfig. What linux distro are you using?
Right now I’m running it in WSL, and it looks like teh ldconfig worked
Thanks!!
