From your paste, it appears it is still there (?). That definitely needs fixing.
Make sure that the modules path is the same on a Pi4, SoapySDRUtil --info
will show you the exact location.
I donât own a AirSPY HF+ so I canât test it.
Jan, think the problem is not the airspyhf driver⊠it was already recognized.
The problem is, that the SatNOGS Flowgraphs are missing⊠and when I do update and aply within the satnogs-setup, Iâm getting this:
Install or remove system packagesâŠ
Get package factsâŠ
Uninstall broken SatNOGS Flowgraphs dependenciesâŠ
Install SatNOGS FlowgraphsâŠ
Retrying⊠(1 of 4)
Retrying⊠(2 of 4)
Retrying⊠(3 of 4)
localhost failed | msg: â/usr/bin/apt-get -y -o âDpkg::Options::=âforce-confdefâ -o âDpkg::Options::=âforce-confoldâ install âsatnogs-flowgraphs=1.4-1ââ failed: E: Version â1.4-1â for âsatnogs-flowgraphsâ was not found
| stdout: Reading package listsâŠ
Building dependency treeâŠ
Reading state informationâŠ
| stderr: E: Version â1.4-1â for âsatnogs-flowgraphsâ was not found
see Debug Information:
Generating support report. Please waitâŠ
dpkg-query: Kein Paket gefunden, das auf satnogs-flowgraphs passt
dpkg-query: Kein Paket gefunden, das auf gr-satnogs passt
dpkg-query: Kein Paket gefunden, das auf gr-soapy passt
âversionsâ: {
âsatnogs-clientâ: â1.6â,
âsatnogs-client-ansibleâ: â202205101826â,
âsatnogs-flowgraphsâ: âunknownâ,
âgr-satnogsâ: âunknownâ,
âgr-soapyâ: âunknownâ,
âgnuradioâ: â3.8.2.0-2â,
âsatnogs-configâ: â0.12â
âstateâ: {
âis-appliedâ: false,
âpending-tagsâ: null
âsystemâ: {
âdateâ: â2022-07-26T16:47:28.897472+00:00â,
âdistributionâ: {
âDESCRIPTIONâ: âRaspbian GNU/Linux 10 (buster)â,
âRELEASEâ: â10â,
âCODENAMEâ: âbusterâ,
âIDâ: âRaspbianâ
Weird, lets see if we can solve this.
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo satnogs-setup
select update
select apply
Lets see if that will fetch the missing packages.
Yes, I did that several times⊠but still same error messages after I select âapplyâ (see above)
I guess I have to start all over again with a fresh imageâŠ
There is one thing we can try, thinking out of the box
sudo apt-get install gr-satnogs
sudo apt-get install gr-soapy
sudo apt-get install satnogs-flowgraphs
HmmmâŠ
Itâs not able to get the file and reports error, unexpected file sizeâŠ
Holen:1 http://download.opensuse.org/repositories/home:/librespace:/satnogs/Raspbian_10 ./ libgnuradio-soapy 2.1.3-1 [51,1 kB]
Fehl:1 http://download.opensuse.org/repositories/home:/librespace:/satnogs/Raspbian_10 ./ libgnuradio-soapy 2.1.3-1
Datei hat eine unerwartete GröĂe (51172 != 51132). Eventuell lĂ€uft gerade eine Spiegel-Synchronisierung? [IP: 2001:638:60f:110::1:2 80]
Hashes of expected file:
No network connectivity, do you an IPv6 enabled network?
Iâm connected through network, everything should be working as usualâŠ
The update of the package repository index file fails due to a filesize mismatch (51172 != 51132). Thus Iâd conclude connectivity to the package repository is given, but something corrupt.
To fix this corruption, you might try and clear the apt-cache, then re-run the index update with
sudo apt-get clean
sudo apt-get update
If this runs successfully, re-try installation of the gr-soapy
package:
I do not understand why the system is in this state though (sd card corruption? interrupted download? ).
Is apt-get update
producing output, or are there also errors.
I did clean and update gave the following errors:
pi@satnogs-vhf:~/SoapyAirspyHF/build $ sudo apt-get update
OK:1 Index of /ansible/ansible/ubuntu trusty InRelease
Holen:2 Index of /raspbian buster InRelease [15,0 kB]
Holen:3 Index of /repositories/home:/librespace:/satnogs/Raspbian_10 ./ InRelease [1.545 B]
OK:4 Index of /debian buster InRelease
Holen:5 Index of /raspbian buster/main armhf Packages [13,0 MB]
Fehl:3 Index of /repositories/home:/librespace:/satnogs/Raspbian_10 ./ InRelease
Die folgenden Signaturen waren ungĂŒltig: EXPKEYSIG 8BD3901736A40B6C home:librespace OBS Project home:librespace@build.opensuse.org
Es wurden 13,0 MB in 7 s geholt (1.998 kB/s).
Paketlisten werden gelesen⊠Fertig
W: WĂ€hrend der ĂberprĂŒfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: Index of /repositories/home:/librespace:/satnogs/Raspbian_10 ./ InRelease: Die folgenden Signaturen waren ungĂŒltig: EXPKEYSIG 8BD3901736A40B6C home:librespace OBS Project home:librespace@build.opensuse.org
W: Fehlschlag beim Holen von http://download.opensuse.org/repositories/home:/librespace:/satnogs/Raspbian_10/./InRelease Die folgenden Signaturen waren ungĂŒltig: EXPKEYSIG 8BD3901736A40B6C home:librespace OBS Project home:librespace@build.opensuse.org
W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
Some sort of problems with the Signatures? Keys?
You never have to start all over. If you do the same thing, youâll be in the same spot. It is easier to just fix this.
Run this:
wget -qO - http://download.opensuse.org/repositories/home:/librespace:/satnogs-unstable/Raspbian_10/Release.key | sudo apt-key --keyring /etc/apt/trusted.gpg add -
The repository is no longer trusted, the command give by @jebba will solve this.
After this, the sudo apt-get update && sudo apt-get upgrade
should no longer produce an error.
That looks good!!! more in a few minutesâŠ
