The sdr issue looks to be related to conflicting udev rules.
This is the one that should be in the udev rules dir.
I suspect this is due to packages installed directly on the host and what ansible (satnogs-setup) is trying to install.
With the docker stack, we don’t need gnuradio, soapy, or the sdr packages on the host.
Regarding the rotator, this is a known limitation (for now and for way too long), here’s my workaround.
