Zathras
September 30, 2017, 6:49am
1
I’ve noticed that the FUNcube subsystem beacon is missing for UKube-1 in the database.
Perhaps the entry can be added.
145.915 MHz FUNcube-2 (subsystem beacon) telemetry 1k2 BPSK
https://amsat-uk.org/tag/ukube-1/
https://www.amsat.org/two-way-satellites/ukube-1/
pierros
September 30, 2017, 11:40am
2
Hey @Zathras !
For transmitter changes/additions/suggestion you can do them directly on the db.satnogs.org Just login and on the satellite page there is a button to suggest changes/additions. Then once submitted moderators look into it and approve it accordingly. Let me know if that worked for you!
Zathras
September 30, 2017, 12:22pm
3
Ok, thanks pierros.
I presumed only networks operators could do that, not dev-network.
Plus I had no login to the database. Now have login and added the transmitter.
Thanks again
pierros
September 30, 2017, 12:23pm
4
…and it is now approved Thanks!
Zathras
September 30, 2017, 12:41pm
5
Thanks pierros.
How long before it appears in scheduling? I’ve had a quick look and not there yet.
pierros
September 30, 2017, 1:27pm
6
Fetch of DB info in Network instances happens every couple of hours. I triggered one manually now. You should be able to see it
