Just configured a ground station in test mode.
I’m trying to record ISS. From my location in No®way this is always below horizon but i’m able to receive and transmit using APRS.
So how can i “force” my SatNOGS to record the pass?
You have set your station’s minimum horizon to 24 degrees, the maximum elevation of the passes for ISS for the next 24hours is between 2 and 18 degrees, so it’s normal to get that ISS is bellow your horizon.
