On the last two passes for Sakura I have seen an additional signal around 10KHz higher than the centre frequency. I don’t have the software to review at the moment, would some one be able to review this observation and try to confirm it’s source?
It’s the CW beacon from KKS-1.
In observation #10571310 starting one minute earlier than yours you can see KSS-1 in the center and SAKURA 10 kHz lower.
Thanks Daniel. Quite an old cube sat still going strong
