[RSP-03] SatNOGS decoder support for GMSK beacon (MR submitted, CI pipeline issue)
finished.
I’m also thinking about adding a Geomap panel to display the position of observers and their amount of reported CW and FSK beacons.
Subject: I’ll handle this—please share the steps
Hi @dl7ndr,
I’ll take care of this and would like to maintain it going forward. Could you please share the steps/workflow to implement and update it (recommeded other sattelite, where to edit, how to deploy changes to Telemetry, and any review process)?
Thanks,
czh00361 (estima5633)
Rymansat project
You may just copy the Geomap from ALSat-1n and change the field callsign to cw_type.
Hi.@dl7ndr
I’ve added two separate Geomap panels on the RSP-03 dashboard—one for CW (cw_type) and one for GMSK (packet_type>=1): 【RSP03 Dashboard】(Grafana)
ALSat-1n’s panel is quite complex (about 31 transformation steps), and I couldn’t get a clean combined panel (overlaying cw_type and packet_type) working in time. With the release on Sep 19 (JST) and planned dashboard edits on Sep 18 (JST), I’ll potpone the two combined panel and consider to refine it during operations.
Could you please review the two panels as they are now?
If @dl7ndr looks good, @deckbsd and @fredysan, I hope to merge RSP03 dashboard into Telemetry ,please
Thanks. Best Regards,
czh00361(estima5633)
Rymansat project
I’ve combined both counts into one Geomap.
Hello @estima5633 ,
Sorry I m a bit less present since I m on holiday right now. But nevertheless, tell when the dashboard is ready and I will deploy it in telemetry :slight_smile: I will
Best regards,
Hi @deckbsd,
Thanks! We’re aiming to finalize the RSP-03 dashboard on Sep 18 (JST). I’ll open a Grafana MR, tag you and @fredy, and ping you when it’s ready for Telemetry deploy. Enjoy your holiday!
Best,
Rymansat project
Hello @estima5633
Thanks you :slight_smile: There is no need for MR regarding dashboard, you can just ping me here when the update needs to be done.
Best regards,
Hi @deckbsd,
dl7ndr has confirmed the RSP-03 updates. Please sync Telemetry Grafana with Scratchpad (combined CW+GMSK Geomap).
Thanks! Best Regards,
Rymansat Project
Hello @estima5633 ,
The udpate of the RSP-03’s dashboard in Telemetry has been done. @fredy i have submitted a new suggestion on the RSP-03 DB page to change the link to the dashboard :slight_smile:
Best regards,
Hi @fredy ,@deckbsd @SA2KNG @tammojan @dl7ndr ,All
We’re happy to share that RSP-03 has successfully obtained its license and operations have officially started on DEC 15.
The signal is very weak, so reception typically requires a 15-element Yagi antenna with an LNA, but we would greatly appreciate your reception reports.
Please submit reports here:
https://rsp03.rymansat.com/en/receiving_report
Thank you for supporting RSP-03!
Rymansat Project
