Hi, just installed this on windows 10.
I got lots of SIZE Errors in rig control: is this normal?
Here is short piece of log in DEBUG level:
2017/11/05 09:41:21|1|send_rigctld_command: SIZE ERROR 2 / 1
2017/11/05 09:41:21|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: Read 10 bytes from rigctld
2017/11/05 09:41:22|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: sending 1 bytes to rigctld as “f
2017/11/05 09:41:22|4|”
2017/11/05 09:41:22|1|send_rigctld_command: SIZE ERROR 2 / 1
2017/11/05 09:41:22|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: Read 10 bytes from rigctld
2017/11/05 09:41:23|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: sending 1 bytes to rigctld as “f
2017/11/05 09:41:23|4|”
2017/11/05 09:41:23|1|send_rigctld_command: SIZE ERROR 2 / 1
2017/11/05 09:41:23|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: Read 10 bytes from rigctld
2017/11/05 09:41:24|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: sending 1 bytes to rigctld as “f
2017/11/05 09:41:24|4|”
2017/11/05 09:41:24|1|send_rigctld_command: SIZE ERROR 2 / 1
2017/11/05 09:41:24|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: Read 10 bytes from rigctld
2017/11/05 09:41:25|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: sending 1 bytes to rigctld as “f
2017/11/05 09:41:25|4|”
2017/11/05 09:41:25|1|send_rigctld_command: SIZE ERROR 2 / 1
2017/11/05 09:41:25|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: Read 10 bytes from rigctld
2017/11/05 09:41:26|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: sending 1 bytes to rigctld as “f
2017/11/05 09:41:26|4|”
2017/11/05 09:41:26|1|send_rigctld_command: SIZE ERROR 2 / 1
2017/11/05 09:41:26|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: Read 10 bytes from rigctld
2017/11/05 09:41:27|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: sending 1 bytes to rigctld as “f
2017/11/05 09:41:27|4|”
2017/11/05 09:41:27|1|send_rigctld_command: SIZE ERROR 2 / 1
2017/11/05 09:41:27|4|…/src/gtk-rig-ctrl.c:send_rigctld_command: Read 10 bytes from rigctld
This was a bug that has been fixed since the last windows package. Currently there is nobody to create new windows package so only outdated package is available.
Alex
