Hi taylorwass,
Thank you for sharing your experience! Here are the details you requested:
1. Operating System: Debian 13 (amd64), Linux kernel 6.12.107+deb13-amd64
2. Installation Method: Installed via APT packages on Debian:
Bash
sudo apt install soapysdr-tools python3-soapysdr soapysdr-module-rtlsdr
3. SoapySDRUtil --info Output:
Plaintext
## Soapy SDR -- the SDR abstraction library ##
Lib Version: v0.8.1-5+b2
API Version: v0.8.0
ABI Version: v0.8
Install root: /usr
Search path: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8
Search path: /usr/local/lib/x86_64-linux-gnu/SoapySDR/modules0.8 (missing)
Search path: /usr/local/lib/SoapySDR/modules0.8 (missing)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libHackRFSupport.so (0.3.4)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libLMS7Support.so (23.11.0)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libRedPitaya.so (0.1.1)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libairspySupport.so (0.2.0)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libaudioSupport.so (0.1.1)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libbladeRFSupport.so (0.4.2)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libmiriSupport.so (0.2.5)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libosmosdrSupport.so (0.2.5)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libremoteSupport.so (0.5.2)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/librfspaceSupport.so (0.2.5)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/librtlsdrSupport.so (0.3.3)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libuhdSupport.so (0.4.1)
Available factories... airspy, audio, bladerf, hackrf, lime, miri, osmosdr, redpitaya, remote, rfspace, rtlsdr, uhd
Available converters...
- CF32 -> [CF32, CS16, CS8, CU16, CU8]
- CS16 -> [CF32, CS16, CS8, CU16, CU8]
- CS32 -> [CS32]
- CS8 -> [CF32, CS16, CS8, CU16, CU8]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- F32 -> [F32, S16, S8, U16, U8]
- S16 -> [F32, S16, S8, U16, U8]
- S32 -> [S32]
- S8 -> [F32, S16, S8, U16, U8]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
Do you remember how you resolved the version issue when you encountered it? Any advice would be greatly appreciated!
Best regards, 73, Yukio / JP7DVX
