Regarding Observation 924 …
Decoded using gr-satellites.
More frames of observation 924.
Tag Debug:
Input Stream: 00
Offset: 989689 Source: correlate_access_code_tag_bb8 Key: syncword Value: 1
Golay decode OK. Bit errors = 0.
RS decode OK. Byte errors: 6.
- MESSAGE DEBUG PRINT PDU VERBOSE *
pdu_length = 258
contents =
0000: 1c 96 f8 7d ef 8e c0 c2 9a 68 61 f7 2b 7a bd eb
0010: b7 12 ce 5a 97 73 cc 1c a2 f3 3e 31 10 85 88 94
0020: cd ee b1 fa 96 ff 81 22 1a f7 79 1c 59 27 58 05
0030: 6d c7 8d 1f 39 d7 8f 44 65 7e 5c 67 21 ae 11 2b
0040: 93 78 63 de 20 3e 02 68 35 3d f2 b9 b2 b8 b6 78
0050: dd 90 39 7d 5d e0 30 df 8a e9 f8 3d 43 d3 3f 53
0060: 37 aa 6b fb 05 7e 04 d0 6b 85 e4 71 64 9d 6d 3d
0070: ba 36 76 d4 bb ee 61 95 15 f9 f0 50 87 8c 44 a6
0080: 6f 55 8f f4 80 ec 09 a0 d7 0b c8 e2 c9 3a da 7b
0090: 74 6c e5 a9 77 dc c3 2a 2b f3 e0 b0 0c 6a 8b b0
00a0: de ab 1f e9 3e 86 c9 41 6e 7d 4c c5 2d dc f3 f6
00b0: a8 56 ca 6b d0 a9 04 fd 94 34 30 34 1d 6c 7f c0
00c0: 7e 58 23 26 00 72 8c 83 5c 6d 89 8b 24 a8 c3 ed
00d0: d1 91 b4 5e 50 76 09 16 bf cf 83 90 1d 59 53 08
00e0: a7 a6 34 e3 37 f6 46 90 23 6a cf f8 ee 6d 43 5a
00f0: ea b5 b9 b1 d3 ab 99 42 7b 6d df 55 5c ce 5c 08
0100: 9a 91
*MESSAGE DEBUG PRINT PDU VERBOSE *
pdu_length = 216
contents =
0000: 00 80 a7 82 58 97 18 dd 79 07 e9 00 4c 00 54 00
0010: 00 00 0e 00 2e 00 4c 00 3b 00 74 00 00 00 04 00
0020: 04 06 e2 00 16 00 16 00 00 00 00 03 4a 03 4a 11
0030: aa 17 2c 17 21 00 00 20 73 00 4d 00 02 00 ad 00
0040: 23 00 05 00 00 00 ff 00 81 00 f6 00 e6 00 8b 00
0050: 17 00 17 00 15 00 15 00 15 00 15 1d 00 00 00 ac
0060: 01 45 08 00 00 00 00 00 00 00 00 00 00 00 00 04
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0090: 00 00 00 00 00 00 00 00 11 03 72 02 fc 00 00 00
00a0: 00 3f 5e da 00 c0 6a dd 00 bf a9 47 00 40 8f 01
00b0: 39 3f 10 82 a9 c3 d3 f1 76 43 5d 6d 59 c3 0e 1c
00c0: f4 03 c2 aa 00 00 42 aa 00 00 42 aa 00 00 22 22
00d0: fb 8f 05 05 be 10 00 01
CSP header:
Priority: 2
Source: 1
Destination: 10
Destination port: 30
Source port: 0
Reserved field: 0
HMAC: 0
XTEA: 0
RDP: 0
CRC: 0
Timestamp: 2017-02-05 12:21:49
Flags: 0x79
Beacon A:
OBC:
Boot count: 2025
Board temp 1: 19.0ºC
Board temp 2: 21.0ºC
Panel temps: [0.0, 3.5, 11.5, 19.0, 14.75, 29.0]ºC
COM:
Bytes corrected by RS: 0
RX packets: 4
RX errors: 4
TX packets: 1762
Last temp A: 22ºC
Last temp B: 22ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.42V
Last TX current: 842mA
Boot count: 4522
EPS:
Boost converter voltages: [5.932, 5.921, 0.0]V
Battery voltage: 8.307V
Current out: (77, 2, 173, 35, 5, 0)mA
Current in: (255, 129, 246)mA
Boost converter current: 230mA
Battery current: 139mA
Temperature sensors: (23, 23, 21, 21, 21, 21)ºC
Output status: 0x1d
EPS reboots: 0
WDT I2C reboots: 172
WDT GND reboots: 325
Boot cause: 8
Latchups: (0, 0, 0, 0, 0, 0)
Battery mode: invalid mode 4
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Average FPS 10sec: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last timestamp: 1970-01-01 00:00:00
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 17ºC
Boot count: 882
Reset cause: 2
Switch status: 0xfc
Burn tries: (0, 0)
ADCS:
Tumble rate: (0.870513916015625, -3.66973876953125, -1.322479248046875)
Tumble norm: (4.468899250030518, 0.564493715763092)
Magnetometer: (-423.88641357421875, 221.42713928222656, -142.11309814453125)
Status: 0x3
Torquer duty: (-85.0, 85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (251, 143, 5, 5, 190, 16, 0, 1)
