Observation 864: GOMX 1 (39430)
Regarding Observation 864
New data from GOMX1!
Tag Debug:
Input Stream: 00
Offset: 1078021 Source: correlate_access_code_tag_bb8 Key: syncword Value: 0
Golay decode OK. Bit errors = 0.
RS decode OK. Byte errors: 5.
  • MESSAGE DEBUG PRINT PDU VERBOSE *
    pdu_length = 258
    contents =
    0000: 1c 96 f8 7d ef 8e c0 c2 99 89 c1 f7 2b 74 ad eb
    0010: b7 12 ce 5a 97 72 cc 00 a2 e9 3e 4e 10 a9 88 94
    0020: cd eb b1 ff 92 6e 81 22 1a f7 79 1c 59 27 58 07
    0030: 6d c7 8d 17 39 5f 8f f9 45 78 5c 75 21 ae 11 2b
    0040: 9b 7f 63 dc 20 3e 02 68 35 e5 f2 71 b3 03 b6 ad
    0050: dd 64 39 7d 5d e0 30 dc 8a 8a f8 3d 43 d3 3f 53
    0060: 37 aa 6c fb 04 72 04 d0 6b 85 e4 71 64 9d 6d 3d
    0070: ba 36 71 d4 bb ec 61 95 14 f9 f0 50 87 8c 44 a6
    0080: 6f 55 8f f4 80 ec 09 a0 d7 03 c8 e2 c9 3a da 7b
    0090: 74 6c e5 a9 77 dc c3 2a 2b f3 e0 b3 0c 68 8a b0
    00a0: de aa 1f e8 3e 65 06 41 91 6d 5c c5 2d c4 61 f6
    00b0: a8 57 a3 d2 d0 a9 fe a9 94 31 c8 33 5d 52 6a 13
    00c0: 7e 51 e7 05 00 72 8c 83 5c ed 89 8b 24 a9 c3 ed
    00d0: d1 91 b4 a0 da 08 3e 94 af cf 80 25 62 c9 81 e0
    00e0: 03 96 fa b8 98 72 69 3b 3f 6f 84 1f a1 2f 6d 2b
    00f0: 91 a0 4e e2 4b 19 02 b1 b6 e6 c0 55 56 f0 48 f3
    0100: 80 81
pdu_length = 216
contents =
0000: 00 80 a7 82 58 94 79 7d 79 07 e7 00 4c 00 54 00
0010: 00 00 0f 00 32 00 56 00 44 00 58 00 00 00 01 00
0020: 01 02 73 00 16 00 16 00 00 00 00 03 48 03 4a 11
0030: a2 17 a4 17 9c 00 06 20 61 00 4d 00 02 00 aa 00
0040: 21 00 05 00 00 00 27 00 49 01 4d 00 33 00 7f 00
0050: 17 00 17 00 16 00 16 00 15 00 15 1d 00 00 00 ab
0060: 01 44 04 00 00 00 00 00 00 00 00 00 00 00 00 03
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0090: 00 00 00 00 00 00 00 00 12 03 70 03 fc 00 01 00
00a0: 01 3f bd 15 00 3f 7a cd 00 bf b1 d5 00 40 8e 68
00b0: 80 3f 10 78 fd c3 d6 09 71 43 63 78 8a c3 07 d8
00c0: d7 03 c2 aa 00 00 c2 aa 00 00 42 aa 00 00 22 22
00d0: 05 05 7b 32 3c 00 00 02
CSP header:
Priority: 2
Source: 1
Destination: 10
Destination port: 30
Source port: 0
Reserved field: 0
HMAC: 0
XTEA: 0
RDP: 0
CRC: 0
Timestamp: 2017-02-03 12:37:17
Flags: 0x79
Beacon A:
OBC:
Boot count: 2023
Board temp 1: 19.0ºC
Board temp 2: 21.0ºC
Panel temps: [0.0, 3.75, 12.5, 21.5, 17.0, 22.0]ºC
COM:
Bytes corrected by RS: 0
RX packets: 1
RX errors: 1
TX packets: 627
Last temp A: 22ºC
Last temp B: 22ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.4V
Last TX current: 842mA
Boot count: 4514
EPS:
Boost converter voltages: [6.0520000000000005, 6.0440000000000005, 0.006]V
Battery voltage: 8.289V
Current out: (77, 2, 170, 33, 5, 0)mA
Current in: (39, 73, 333)mA
Boost converter current: 51mA
Battery current: 127mA
Temperature sensors: (23, 23, 22, 22, 21, 21)ºC
Output status: 0x1d
EPS reboots: 0
WDT I2C reboots: 171
WDT GND reboots: 324
Boot cause: 4
Latchups: (0, 0, 0, 0, 0, 0)
Battery mode: invalid mode 3
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Average FPS 10sec: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last timestamp: 1970-01-01 00:00:00
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 18ºC
Boot count: 880
Reset cause: 3
Switch status: 0xfc
Burn tries: (1, 1)
ADCS:
Tumble rate: (1.477203369140625, 0.9796905517578125, -1.389312744140625)
Tumble norm: (4.45025634765625, 0.5643461346626282)
Magnetometer: (-428.0737609863281, 227.47085571289062, -135.84703063964844)
Status: 0x3
Torquer duty: (-85.0, -85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (5, 5, 123, 50, 60, 0, 0, 2)
