Regarding Observation 750324 … New setup and this may be my first good observation, was hoping to get a second opinion. There looks to be some signal ending a little after 200 seconds, vertical lines as opposed to the noise curves. Am I on the right track?
I believe you are correct. I think that the telemetry from the same sat is also visible on the left side of the waterfall (although I guess that shouldn’t play into the vetting of the CW observation).
–Roy
K3RLD
You are both right! Indeed this signal at the middle is the CW of CAS-4A and the other one at -15KHz is from CAS-4A too.
By the way… @jDkelly Welcome to SatNOGS!
