Regarding Observation 59311 …
After investigating the last obs, I think this is a ‘false positive’.
Yes, there is data, and its source is a satellite, but not SIMPL (QIKCOM-1)!
I used direwolf for an attempt to decode the packets at the end of the pass:
Digipeater ARISS audio level = 42(6/8) [NONE] ||::_____
[0.1] TA1FL-4>T0UT91,PSAT,ARISS*:'9.Ll <0x1c>`/]NE MUTLU TURKUM DIYENE=<0x0d>
U frame UI: p/f=0, No layer 3 protocol implemented., length = 64
dest T0UT91 0 c/r=0 res=3 last=0
source TA1FL 4 c/r=1 res=3 last=0
digi 1 PSAT 0 h=1 res=3 last=0
digi 2 ARISS 0 h=1 res=3 last=1
000: a8 60 aa a8 72 62 60 a8 82 62 8c 98 40 e8 a0 a6 .`..rb`..b..@...
010: 82 a8 40 40 e0 82 a4 92 a6 a6 40 e1 03 f0 27 39 ..@@......@...'9
020: 2e 4c 6c 20 1c 60 2f 5d 4e 45 20 4d 55 54 4c 55 .Ll .`/]NE MUTLU
030: 20 54 55 52 4b 55 4d 20 44 49 59 45 4e 45 3d 0d TURKUM DIYENE=.
MIC-E, Dish Antenna, Kenwood TM-D710, In Service
N 40 54.9100, E 029 18.4800, 0 MPH
Digipeater ARISS audio level = 33(7/6) [NONE] |||||:___
[0.2] TA1FL-4>T0UT91,PSAT,ARISS*:'9.Ll <0x1c>`/]NE MUTLU TURKUM DIYENE=<0x0d>
Digipeater ARISS audio level = 29(7/6) [NONE] ||||::___
[0.2] IR0UGN-1>CQ,PSAT,ARISS*:=/90C,Qc3x` BJN62JE IZ0QWM http://www.kwos.it
U frame UI: p/f=0, No layer 3 protocol implemented., length = 76
dest CQ 0 c/r=0 res=3 last=0
source IR0UGN 1 c/r=0 res=3 last=0
000: 86 a2 40 40 40 40 60 92 a4 60 aa 8e 9c 62 a0 a6 ..@@@@`..`...b..
010: 82 a8 40 40 e0 82 a4 92 a6 a6 40 e1 03 f0 3d 2f ..@@......@...=/
020: 39 30 43 2c 51 63 33 78 60 20 20 42 4a 4e 36 32 90C,Qc3x` BJN62
030: 4a 45 20 49 5a 30 51 57 4d 20 68 74 74 70 3a 2f JE IZ0QWM http:/
040: 2f 77 77 77 2e 6b 77 6f 73 2e 69 74 /www.kwos.it
Position, Dish Antenna
N 42 11.2501, E 012 47.4999
Digipeater ARISS audio level = 37(7/6) [NONE] ::::|:___
[0.4] TA1FL-4>T0UT91,PSAT,ARISS*:'9.Ll <0x1c>`/]NE MUTLU TURKUM DIYENE=<0x0d>
Then I tried to use the time-controller of gpredict, which gave me the following:
So relatively sure this was NO-84, overlapping the pass of SIMPL.
