Regarding Observation 466673 …
Hi I am having a hard time decoding this capture. Do you think the signal is good enough to do so. I haven’t been able to decode BPSK at all. I notice that some of the signa after the dots gets cut off when I run the signal through soundmodem and observe the signal in the waterfall. Not sure if that matters. Any suggestions would be helpful.
