Hi, the waterfall of this Observation 304114 looks quite good (strong signal), but there is no data demodulated.
In the log I found this error:
Oct 30 11:04:49 SATNOGS satnogs-client[483]: 2018-10-30 11:04:49,294 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2018-10-30 10:05:48 UTC)” executed successfully
Oct 30 11:05:26 SATNOGS satnogs-client[483]: terminate called after throwing an instance of ‘std::runtime_error’
Oct 30 11:05:26 SATNOGS satnogs-client[483]: what(): block lookup failed! block not found!
Oct 30 11:05:26 SATNOGS satnogs-client[483]: Aborted
Oct 30 11:05:26 SATNOGS satnogs-client[483]: 2018-10-30 11:05:26,182 - satnogsclient - INFO - Closing socket: <socket._socketobject object at 0x7fe1a02d1360>
Oct 30 11:05:31 SATNOGS satnogs-client[483]: 2018-10-30 11:05:31,177 - satnogsclient - INFO - Closing socket: <socket._socketobject object at 0x7fe1c1929d70>
Could it be this the reason for the missing data? Is there a way to re-process the pass to try to get them?
Tnx!
Alberto
