How do I track who is flagging my passes as ‘successful’? They’re currently without data.
I haven’t done this so assume an admin is. 73 C
Regarding Observation 300001 …
Hello,
You can check who vetted an observation by letting your pointer of the tag (good/bad/failed) on the observation page.
According to the vetting rules this is a good observation.
PS I vetted this one
EDIT Vetting can be done by anyone for any observation, it’s not limited to admins.
EDIT2 I’m going later manually (semi automatically in reality) to upload data on SSTV observations.
I had a feeling it was you Fredy
So what’s the process for the SSTV images?
From your message it sounds like they’re not locally decoded.
73s, Chris
Edit1: When is ‘later’?
I have written some scripts and made some changes in qsstv decoder, so I download all the sstv observations audios and then passing them through the changed qsstv decoder. This results to png images with the right name and timestamp.
Then I upload all these decoded images into the observations… depending on the volume of the observations these could take from a couple of hours to a couple of days.
Later is in a couple of hours
