Regarding Observation 1631 …
Decoder gr-satellites GOMX-1.
2017-03-02 11:24:35
Timestamp: 2017-03-02 05:03:51
Flags: 0x79
Beacon A:
OBC:
Boot count: 2045
Board temp 1: 19.0ºC
Board temp 2: 20.0ºC
Panel temps: [0.0, 11.0, 26.5, 12.5, 8.5, 23.5]ºC
COM:
Bytes corrected by RS: 0
RX packets: 3
RX errors: 3
TX packets: 1617
Last temp A: 21ºC
Last temp B: 21ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.4V
Last TX current: 842mA
Boot count: 4632
EPS:
Boost converter voltages: [7.405, 7.43, 0.0]V
Battery voltage: 8.251V
Current out: (4, 2, 132, 33, 5, 0)mA
Current in: (4, 12, 0)mA
Boost converter current: 0mA
Battery current: 176mA
Temperature sensors: (22, 22, 21, 21, 20, 19)ºC
Output status: 0x1c
EPS reboots: 0
WDT I2C reboots: 179
WDT GND reboots: 338
Boot cause: 4
Latchups: (0, 0, 0, 0, 0, 0)
Battery mode: invalid mode 3
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Average FPS 10sec: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last timestamp: 1970-01-01 00:00:00
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 16ºC
Boot count: 914
Reset cause: 3
Switch status: 0xfc
Burn tries: (1, 1)
ADCS:
Tumble rate: (2.601165771484375, -1.2516021728515625, -1.0932159423828125)
Tumble norm: (4.2572455406188965, 0.5565115213394165)
Magnetometer: (-360.1122741699219, 155.6861114501953, -130.5299072265625)
Status: 0x3
Torquer duty: (-85.0, 85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (5, 44, 72, 7, 5, 0, 0, 0)
2017-03-02 11:24:47
Timestamp: 2017-03-02 05:04:11
Flags: 0x79
Beacon A:
OBC:
Boot count: 2045
Panel temps: [0.0, 9.5, 24.25, 12.25, 8.0, 21.75]ºC
COM:
RX packets: 3
RX errors: 3
TX packets: 1618
Last temp A: 21ºC
Last temp B: 22ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.42V
Boot count: 4632
EPS:
Boost converter voltages: [6.702, 6.691, 0.0]V
Battery voltage: 8.307V
Current out: (94, 2, 175, 40, 5, 0)mA
Current in: (152, 149, 0)mA
Boost converter current: 200mA
Battery current: 139mA
Temperature sensors: (21, 22, 21, 21, 20, 19)ºC
Output status: 0x1d
EPS reboots: 0
Boot cause: 4
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 16ºC
Boot count: 914
Reset cause: 3
Switch status: 0xfc
Burn tries: (1, 1)
ADCS:
Tumble rate: (-1.664581298828125, -0.2623748779296875, -0.46478271484375)
Tumble norm: (4.242710113525391, 0.556164562702179)
Magnetometer: (-367.8414611816406, 153.82394409179688, -128.1632080078125)
Status: 0x3
Torquer duty: (85.0, 85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (4, 6, 250, 255, 5, 0, 0, 0)
2017-03-02 11:24:57
Timestamp: 2017-03-02 05:04:21
Flags: 0x79
Beacon A:
OBC:
Boot count: 2045
Panel temps: [0.0, 9.0, 22.75, 12.25, 8.0, 21.0]ºC
COM:
RX packets: 3
RX errors: 3
TX packets: 1619
Last temp A: 21ºC
Last temp B: 21ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.43V
Boot count: 4632
EPS:
Boost converter voltages: [5.317, 5.303, 0.0]V
Battery voltage: 8.317V
Current out: (55, 2, 170, 40, 5, 0)mA
Current in: (238, 217, 0)mA
Boost converter current: 236mA
Battery current: 127mA
Output status: 0x1d
EPS reboots: 0
Boot cause: 4
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 16ºC
Boot count: 914
Reset cause: 3
Switch status: 0xfc
Burn tries: (1, 1)
ADCS:
Tumble rate: (-3.099365234375, 0.3017425537109375, 1.1082839965820312)
Tumble norm: (4.236179828643799, 0.5559769868850708)
Magnetometer: (-369.92376708984375, 155.7881622314453, -123.92786407470703)
Status: 0x3
Torquer duty: (85.0, -85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (4, 5, 63, 86, 5, 0, 17, 0)
2017-03-02 11:25:03
Timestamp: 2017-03-02 05:04:41
Flags: 0x79
Beacon A:
OBC:
Boot count: 2045
Panel temps: [0.0, 7.75, 20.75, 13.75, 9.25, 19.0]ºC
COM:
RX packets: 3
RX errors: 3
TX packets: 1621
Last temp A: 21ºC
Last temp B: 21ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Boot count: 4632
EPS:
Boost converter voltages: [2.541, 2.5300000000000002, 0.0]V
Battery voltage: 8.27V
Current out: (4, 2, 65, 45, 5, 0)mA
Current in: (365, 306, 0)mA
Boost converter current: 146mA
Output status: 0x1c
EPS reboots: 0
Boot cause: 4
Battery mode: invalid mode 4
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 16ºC
Boot count: 914
Reset cause: 3
Switch status: 0xfc
Burn tries: (1, 1)
ADCS:
Tumble rate: (-1.056365966796875, 0.8348846435546875, -0.6604766845703125)
Tumble norm: (4.229201793670654, 0.5557120442390442)
Magnetometer: (-366.0072937011719, 155.7330322265625, -126.14208221435547)
Status: 0x3
ADS state: 0x22
ACS state: 0x22
Sun sensor: (4, 5, 130, 180, 5, 0, 17, 0)
2017-03-02 11:25:14
Timestamp: 2017-03-02 05:04:51
Flags: 0x69
Beacon A:
OBC:
Boot count: 2045
Panel temps: [0.0, 7.0, 19.5, 15.0, 10.75, 18.25]ºC
COM:
RX packets: 3
RX errors: 3
TX packets: 1622
Last temp A: 21ºC
Last temp B: 21ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Boot count: 4632
EPS:
Output status: 0x1c
EPS reboots: 0
Boot cause: 4
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 16ºC
Boot count: 914
Reset cause: 3
Switch status: 0xfc
Burn tries: (1, 1)
ADCS:
Tumble rate: (1.821136474609375, -0.3401947021484375, -1.4678192138671875)
Tumble norm: (4.227259159088135, 0.5555514097213745)
Magnetometer: (-365.8580017089844, 149.53009033203125, -123.79461669921875)
Status: 0x3
ADS state: 0x22
ACS state: 0x22
Sun sensor: (5, 5, 145, 214, 6, 0, 17, 0)
2017-03-02 11:25:52
Timestamp: 2017-03-02 05:05:51
Flags: 0x79
Beacon A:
OBC:
Boot count: 2045
Panel temps: [0.0, 4.75, 13.5, 20.25, 18.5, 20.25]ºC
COM:
RX packets: 3
RX errors: 3
TX packets: 1627
Last temp A: 21ºC
Last temp B: 21ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.41V
Boot count: 4632
EPS:
Boost converter voltages: [4.436, 4.426, 0.006]V
Battery voltage: 8.26V
Current out: (4, 2, 132, 35, 5, 0)mA
Current in: (140, 111, 302)mA
Boost converter current: 93mA
Output status: 0x1c
EPS reboots: 0
Boot cause: 4
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 16ºC
Boot count: 914
Reset cause: 3
Switch status: 0xfc
Burn tries: (1, 1)
ADCS:
Tumble rate: (-0.722198486328125, 1.6512298583984375, -2.58697509765625)
Tumble norm: (4.224639892578125, 0.5552835464477539)
Magnetometer: (-358.2247009277344, 164.15536499023438, -141.52182006835938)
Status: 0x3
ADS state: 0x22
ACS state: 0x22
Sun sensor: (4, 5, 224, 215, 43, 0, 0, 2)
2017-03-02 11:26:59
Timestamp: 2017-03-02 05:07:11
Flags: 0x69
Beacon A:
OBC:
Boot count: 2045
Panel temps: [0.0, 6.75, 15.75, 17.5, 14.0, 31.25]ºC
COM:
RX packets: 3
RX errors: 3
TX packets: 1635
Last temp A: 21ºC
Last temp B: 21ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Boot count: 4632
EPS:
Boost converter voltages: [2.959, 2.9370000000000003, 0.0]V
Current out: (4, 2, 153, 42, 5, 0)mA
Current in: (382, 256, 56)mA
Boost converter current: 171mA
Temperature sensors: (22, 22, 20, 20, 20, 20)ºC
Output status: 0x1c
EPS reboots: 0
Boot cause: 4
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 17ºC
Boot count: 914
Reset cause: 3
Switch status: 0xfc
Burn tries: (1, 1)
ADCS:
Tumble rate: (4.167327880859375, 0.4848480224609375, -1.5236282348632812)
Tumble norm: (4.242269992828369, 0.5558919906616211)
Magnetometer: (-330.9062194824219, 142.04525756835938, -117.91055297851562)
Status: 0x3
Torquer duty: (-85.0, -85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (109, 238, 4, 5, 140, 17, 0, 0)
2017-03-02 11:27:17
Timestamp: 2017-03-02 05:07:31
Flags: 0x79
Beacon A:
OBC:
Boot count: 2045
Board temp 1: 18.0ºC
Panel temps: [0.0, 10.0, 20.25, 16.5, 12.75, 30.0]ºC
COM:
RX packets: 3
RX errors: 3
TX packets: 1637
Last temp A: 21ºC
Last temp B: 21ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Boot count: 4632
EPS:
Boost converter voltages: [1.847, 1.829, 0.0]V
Current out: (4, 2, 150, 47, 5, 0)mA
Current in: (417, 300, 0)mA
Boost converter current: 106mA
Output status: 0x1c
EPS reboots: 0
Boot cause: 4
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 17ºC
Boot count: 914
Reset cause: 3
Switch status: 0xfc
Burn tries: (1, 1)
ADCS:
Tumble rate: (-2.11669921875, 0.1065826416015625, 2.8438186645507812)
Tumble norm: (4.23179817199707, 0.5561428070068359)
Magnetometer: (-326.7543640136719, 131.6280517578125, -115.50130462646484)
Status: 0x3
Torquer duty: (85.0, -85.0, -85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (115, 229, 5, 5, 6, 17, 0, 0)
2017-03-02 11:27:27
Timestamp: 2017-03-02 05:07:41
Flags: 0x79
Beacon A:
OBC:
Boot count: 2045
Panel temps: [0.0, 11.5, 22.75, 15.75, 12.25, 29.0]ºC
COM:
RX packets: 3
RX errors: 3
TX packets: 1638
Last temp A: 21ºC
Last temp B: 21ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Boot count: 4632
EPS:
Boost converter voltages: [2.021, 1.993, 0.0]V
Current out: (4, 2, 132, 38, 5, 0)mA
Current in: (397, 265, 0)mA
Output status: 0x1c
EPS reboots: 0
Boot cause: 4
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 17ºC
Boot count: 914
Reset cause: 3
Switch status: 0xfc
Burn tries: (1, 1)
ADCS:
Tumble rate: (-0.143585205078125, -1.94793701171875, -1.5122222900390625)
Tumble norm: (4.2288737297058105, 0.5561912655830383)
Magnetometer: (-322.4275817871094, 127.98538970947266, -132.50445556640625)
Status: 0x3
ADS state: 0x22
ACS state: 0x22
Sun sensor: (78, 204, 4, 5, 5, 17, 0, 0)
