I am sure a GPSDO will not help here. And GPSDO’s need to be selected very carefully. For Satnogs you need one with very low phase-jitter, otherwilse you get poor decoding performance for all phase-based modes.
But what I noticed first, when checking your observation was the small dynamic range of 90-40=50dB. My observation of the same pass from the pluto-clone (zynx7010 / TCXO) shows much higher dynamic range of 98-12=86dB https://network.satnogs.org/observations/15306550/
From the waterfall for me it looks that something is overdriven or noisy. Did you try with lower gain settings? I would try to reduce by 10dB for a first check.This is very critical and a few db can make a big difference. I am permanentely playing with the gain settings of my Lime and pluto.
73,
Stefan/OE6ISP
EDIT: I also checked the WF from my Lime https://network.satnogs.org/observations/15303054/ and it also shows 85dB dynamic range for the same pass, so it seems something (LNA?) runs into saturation in your setup
Thanks a lot for all the input! I guess I will skip the GPSDO for know and focus again on SNR. I adjusted it month ago, but seems like something has changed, and I have to find out what exactly.
@PE0SAT I will compare your settings with mine and test a few runs
@bali I wrote a script for that to calculate different positions. I have measured the results and it is spot on. I can try to make a clean version if this could help others.
I analysed a few more passes and compared the results to other stations with similar overflights. I think the adjusted airspy settings have improved the results. I will keep an eye on this for a few days. Last pass from yesterday https://network.satnogs.org/observations/15331696/
