Observation 15280322: CRIMSON-1 (98238)
Regarding Observation 15280322 …
Why is not decoding CRIMSON-1? Signal is very strong
73 de EA5WA Juan Carlos
Good evening Juan Carlos,
Can you check your SDR ppm value, my guess currently the LO deviation is to high.
Using the following gr-satellites Yaml you can successful decode the observation.
norad: 98238
  &tlm AX25 Telemetry:
    telemetry: ax25
  2k4 BPSK AX.25 G3RUH downlink:
    frequency: 437.125e+6
    modulation: BPSK
    baudrate: 2400
    framing: AX.25 G3RUH
    - *tlm
gr_satellites CRIMSON-1.yml --wavfile 15280322.ogg --samp_rate 48e3 --f_offset 12000
-> Packet from 2k4 BPSK AX.25 G3RUH downlink
Container:
    header = Container:
        addresses = ListContainer:
            Container:
                callsign = u'CQ' (total 2)
                ssid = Container:
                    ch = True
                    ssid = 0
                    extension = False
            Container:
                callsign = u'9V1CRM' (total 6)
                ssid = Container:
                    ch = False
                    ssid = 0
                    extension = True
        control = 0x03
        pid = 0xF0
    info = b'\x08\x02\xc4\xa7\x00e\x10\x04\n2o\xe6U\x00\x00\x00\n@@Q\x0e\x00\x00\x00\x00\xc3,R\x07K\xb6\x8e\x12\x19\xd5\xd8"LWl\xbb\xb5P\x0fk\x8f\xe6\xdc\x1f\xa7\x93!\xbc\xe1a\xda\xa7\x1bx;\x15\x19\xb6F\x01\xa3\xec|\xb5\x8d\x0eRK\xb0\x1cS`wN5\xf9\xd1\x97F;\xd2\xcf*\x8c\xbc\x9fj\xa0\x7fN\xeb\xee\xfb\xbe\x91\xf8\x17\xf1ZRlt.' (total 108)
CRIMSON-1
#15280322
Hi Jan.
Many thanks for the info.
Unfortunately I’m not a expert, and I dont know how to fix that.
Satnogs has become something that’s beyond me
Hello Juan Carlos,
It seems your RTL-SDR LO is a bit off and therefor the received signal is not close enough to the center frequency and causes the observation to fail.
Therefor you need to find this correction and add it to your SatNOGS client config.
This value SATNOGS_PPM_ERROR: needs to be configured.
You can find a tutorial on this community page.
Hi Jan:
Many thanks for the link.
Finally offset measured by kal was -1.35 (average absolute error: -1.357 ppm). I don’t know if is wrong enough to not decode anything from CRIMSON-1
Could you schedule some observations from CRIMSON-1 to check if it works?
Hi Juan Carlos,
The PPM value can only be an int so you need to change it to 1 or 2, I would suggest to change it to 1.
Let me know when that is done, then we will create some CRIMSON-1 obs.
Many thanks Jan
Done
This obs looks fine and still no decode, maybe update the client and see if that will help, you are on 2.1.2 and the latest is 2.1.4.
I tried to remote login, but that isn’t working anymore.
Hi Jan:
Sorry, now is under a vpn.
I’ll try to update
Can you also have a look at the logs, maybe they also give us more information to work with.
After updating, I’ve started to get decodes from FrontierSat, but NOT from CRIMSON-1
Where are the logs located?
Many thanks
List the containers to find the satnogs-client container NAME:
docker container ls
CONTAINER ID   IMAGE                                  COMMAND                  CREATED         STATUS                PORTS                                         NAMES
a9cfe3998731   librespace/satnogs-client:latest       "satnogs-client"         3 weeks ago     Up 2 days                                                           satnogs-1696
6b2a870b2371   librespace/hamlib:4.5.4                "/usr/local/bin/dock…"   3 weeks ago     Up 2 days                                                           satnogs-1696-rigctld
Then use docker log -t <container name> or docker log -tf <container name>
Maybe you have to add sudo to the docker commands.
ea5wa@SatnogsRaspberry:~ $ docker logs satnogs_satnogs-client
/opt/pipx/venvs/satnogs-client/lib/python3.11/site-packages/matplotlib/projections/init.py:63: UserWarning: Unable to import Axes3D. This may be due to multiple versions of Matplotlib being installed (e.g. as a system package and as a pip package). As a result, the 3D projection is not available.
warnings.warn("Unable to import Axes3D. This may be due to multiple versions of "
rot_init called
initrots4_dummy: _init called
rot_register (1)
rot_register (2)
dummy_rot_init called
rot_open called
dummy_rot_open called
dummy_rot_open: dummy rotator so simulating speed
rot_get_position called
dummy_rot_get_position called
rot_get_position: got az=0.00, el=0.00
rot_set_position called az=196.21 el=0.42
rot_set_position: south_zero=0
dummy_rot_set_position called: 196.21 0.42
ZMQ FRAME SUB Connecting to 127.0.0.1:16887
ZMQ audio SUB Connecting to 127.0.0.1:16889
rig_check_rig_caps: p1=0x7f7cc80640, p2=0x7f7cc86bc0, rig_model=0x7f7cc80640, macro_name=0x7f7cc86bc0
initrigs4_dummy: _init called
rig_init: rig_model=Hamlib NET rigctl
rig_init: rx_range_list1 is empty, using rx_range_list2
rig_init: rig does not have tx_range!!
netrigctl_init version 20230106.0
[INFO] Opening Generic RTL2832U OEM :: 00000001…
[R82XX] PLL not locked!
correlate_access_code_tag_bb :debug: Access code: 930b51de
correlate_access_code_tag_bb :debug: Mask: ffffffff
[INFO] Using format CF32.
Allocating 15 zero-copy buffers
correlate_access_code_tag_bb :debug: writing tag at sample 180464
correlate_access_code_tag_bb :debug: writing tag at sample 271509
correlate_access_code_tag_bb :debug: writing tag at sample 301633
correlate_access_code_tag_bb :debug: writing tag at sample 361609
correlate_access_code_tag_bb :debug: writing tag at sample 431561
correlate_access_code_tag_bb :debug: writing tag at sample 462494
correlate_access_code_tag_bb :debug: writing tag at sample 604295
correlate_access_code_tag_bb :debug: writing tag at sample 607198
correlate_access_code_tag_bb :debug: writing tag at sample 705000
correlate_access_code_tag_bb :debug: writing tag at sample 752433
correlate_access_code_tag_bb :debug: writing tag at sample 758171
correlate_access_code_tag_bb :debug: writing tag at sample 787901
correlate_access_code_tag_bb :debug: writing tag at sample 815929
correlate_access_code_tag_bb :debug: writing tag at sample 952570
correlate_access_code_tag_bb :debug: writing tag at sample 974081
correlate_access_code_tag_bb :debug: writing tag at sample 978921
correlate_access_code_tag_bb :debug: writing tag at sample 3350423
correlate_access_code_tag_bb :debug: writing tag at sample 3354971
correlate_access_code_tag_bb :debug: writing tag at sample 3359770
correlate_access_code_tag_bb :debug: writing tag at sample 3366169
correlate_access_code_tag_bb :debug: writing tag at sample 3369374
correlate_access_code_tag_bb :debug: writing tag at sample 3373867
correlate_access_code_tag_bb :debug: writing tag at sample 3499006
correlate_access_code_tag_bb :debug: writing tag at sample 3500501
correlate_access_code_tag_bb :debug: writing tag at sample 3503802
correlate_access_code_tag_bb :debug: writing tag at sample 3505297
correlate_access_code_tag_bb :debug: writing tag at sample 3513402
correlate_access_code_tag_bb :debug: writing tag at sample 3514897
netrigctl_close: done
rig_check_rig_caps: p1=0x7f78610640, p2=0x7f78616bc0, rig_model=0x7f78610640, macro_name=0x7f78616bc0
ERROR satnogsclient.scheduler.tasks Upload of waterfall_15314088_2026-10-29T13-24-14.png for observation 15314088 failed, response status code: 400
rig_check_rig_caps: p1=0x7fa2f10640, p2=0x7fa2f16bc0, rig_model=0x7fa2f10640, macro_name=0x7fa2f16bc0
