Regarding Observation 140206 …
A NOAA 19 pass above Russia.
Impressive!
Is the main improvement in your system due to the removal of the USB cable shield?
Very nice. Can you describe your hardware?
73,
The most important thing I did: Put my QFH on the roof. Not under the roof. And yes: The removal of the shield from the USB cable creates less interference on my setup. I can’t say if it’s a good thing or not – electrically; safety. For me it works!
Sure. Raspberry Pi 2, TP-Link TL-WN822N, RTLSDR R820T2 unmodified, satellite inline preamp setup – the same one you can see here: http://www.satellitenwelt.de/equipment.htm, a very old DIY QFH antenna I build years ago.
My good ole antenna. A bit out of shape. But it seems to works…
The high passes are ok:
https://network.satnogs.org/media/data_obs/140213/data_140213_2018-05-21T04-00-19_ui8nc7x.png
