Observation 13427094: DUCHIFAT-1 (40021)
Regarding Observation 13427094 …I am quite shure that the signal is not caused by Duchifat-1 - but my question is now - should I rate the observation with signal or no signal.
Thanks for advice.
From Operation - SatNOGS Wiki
  • With Signal
    • You should vet waterfall as “With Signal” when it is clear from the waterfall that the observed satellite is present. Keyboard Shortcut ‘g’.
  • Without Signal
    • You should vet waterfall as “Without Signal” when by examining the waterfall it is obvious that the observed satellite isn’t present. Keyboard Shortcut ‘b’.
So, in this case that satellite signals are not visible, you should vet the waterfall as “Without Singal”.
Thanks.
Sounds like local interference and yes set to bad.
I had a local mosque / call to prayer in one of my observations had me really confused!
Best 73
James M0JFP
