Regarding Observation 12643735…
Any idea what the repeating at approximately 125 seconds stripes are? Doesn’t sound like external noise, more like a peak in the reception gain?
The stripes are gone after changing the SATNOGS_RX_SAMP_RATE from 2e6 to 2.048e6
interesting. btw nice station. what model of sdrplay you used ?
It is a RSP1A
Would you like to try setting it to 250k = 250e3 at your new station. i’m curious is it work fine or any difference result. thank you
I would set it to 256e3 - I think the stripes were caused by the rate not being a power of 2
I changed the setting for another station with identical h/w - SatNOGS Network - Ground Station Sofia SAT Club - LZ1GNU
256e3 was not supported by the radio, changed it to 250e3
I don’t see any major difference between the received signals - here is the comparison:
i think 12648280 is better
