Regarding Observation 1170 …
Decoder gr-satellites GOMX-1
Frames 7.
- MESSAGE DEBUG PRINT PDU VERBOSE *
pdu_length = 258
contents =
0000: 1c 96 f8 7d ef 8e c0 c2 92 46 05 f7 2b 7d ad f7
0010: b7 1e ce 5a 97 4a cc 1d a2 98 3e 51 10 76 88 94
0020: cd ee b1 fa 93 92 81 23 1a f6 79 1c 59 27 58 05
0030: 6d c7 8d 70 20 e2 96 36 45 7e 5c 67 21 a5 11 2b
0040: 9b 4c 63 de 20 30 02 68 34 d6 f3 60 b2 d2 b6 4a
0050: dd d0 39 7c 5d e1 30 dc 8a eb f8 3d 43 d3 3f 53
0060: 37 aa 69 f8 08 7e 04 d0 6b 85 e4 71 64 9d 6d 3d
0070: ba 36 76 d4 bb ee 61 95 15 f9 f0 50 87 8c 44 a6
0080: 6f 55 8f f4 80 ec 09 a0 ff 0b c8 e2 c9 3a da 7b
0090: 74 6c e5 a9 77 dc c3 2a 2b f3 e0 b3 0c 62 8b b0
00a0: de ab 1f e9 3e 67 92 41 10 3c 81 45 2c ab b3 f6
00b0: a8 56 4c 8a d0 ab 72 b2 94 49 a1 ec 5d 10 59 11
00c0: 7f ab 4e 94 00 72 8c 83 5c 6d 89 8b 24 a9 c3 ed
00d0: d1 91 b4 6d a0 76 0a ac be cf 83 d8 0d dc af 61
00e0: 63 60 35 2c 44 91 a5 e7 87 c1 87 a7 98 c0 ff 94
00f0: bb de 7a c3 42 1c f2 e0 0f 0c ac 55 51 30 83 80
0100: ff bb
Timestamp: 2017-02-11 16:07:21
Flags: 0x79
Beacon A:
OBC:
Boot count: 2030
Board temp 1: 20.0ºC
Board temp 2: 22.0ºC
Panel temps: [0.0, 13.75, 11.75, 9.75, 22.75, 33.75]ºC -
COM:
Bytes corrected by RS: 0
RX packets: 4
RX errors: 4
TX packets: 911
Last temp A: 23ºC
Last temp B: 23ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.42V
Last TX current: 842mA
Boot count: 4549 -
EPS:
Boost converter voltages: [3.609, 3.603, 0.0]V
Battery voltage: 8.307V
Current out: (70, 2, 153, 35, 11, 0)mA
Current in: (276, 344, 92)mA
Boost converter current: 212mA
Battery current: 139mA
Temperature sensors: (23, 24, 22, 23, 21, 21)ºC
Output status: 0x1d
EPS reboots: 0
WDT I2C reboots: 174
WDT GND reboots: 328
Boot cause: 8
Latchups: (0, 0, 0, 0, 0, 0)
Battery mode: invalid mode 4 -
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Average FPS 10sec: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last timestamp: 1970-01-01 00:00:00
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0 -
HUB:
Temp: 18ºC
Boot count: 890
Reset cause: 2
Switch status: 0xfc
Burn tries: (0, 0) -
ADCS:
Tumble rate: (1.496124267578125, -1.3364410400390625, -0.42583465576171875)
Tumble norm: (4.485332489013672, 0.5740493535995483)
Magnetometer: (-348.75531005859375, 161.2950439453125, -126.72123718261719)
Status: 0x3
Torquer duty: (-85.0, 85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (200, 127, 5, 6, 4, 17, 0, 1)
