Regarding Observation 1150 …
Decoder gr-satellites GOMX-1.
Frames 36.
- MESSAGE DEBUG PRINT PDU VERBOSE *
pdu_length = 258
contents =
0000: 1c 96 f8 7d ef 8e c0 c2 93 3e 93 f7 2b 7d ad f7
0010: b7 12 ce 5a 97 2f cc 6f a2 9b 3e 37 10 96 88 94
0020: cd ee b1 fa 95 44 81 23 1a f7 79 1c 59 27 5c 07
0030: 6d c7 8d 77 37 23 81 ab 45 7e 5c 7e 21 aa 11 2b
0040: 9b b7 63 de 20 3e 02 68 35 dd f2 14 b2 4e b6 82
0050: dd 7d 39 7d 5d e0 30 dc 8a ea f8 3d 43 d3 3f 53
0060: 37 aa 69 fb 08 7e 04 d0 6b 85 e4 71 64 9d 6d 3d
0070: ba 36 71 d4 bb ee 61 95 15 f9 f0 50 87 8c 44 a6
0080: 6f 55 8f f4 80 ec 09 a0 d7 0b c8 e2 c9 3a ca 7b
0090: 74 6c e5 a9 77 dc c3 2a 2b f3 e0 b3 0c 62 8b b0
00a0: de ab 1f e9 41 86 58 c1 90 80 fc c5 2c 13 9c f6
00b0: a8 57 35 b9 d0 1e 99 50 94 7d f2 b5 5c de 60 44
00c0: 7e 59 14 d4 00 72 8c 83 5c ed 89 8b 24 a9 c3 ed
00d0: d1 91 b4 e9 e7 7f 0b ac af cf 82 04 5a 10 99 2f
00e0: f1 6a d5 42 59 60 f6 f9 bd 43 5e 63 1e a9 3a 7d
00f0: c5 8a 1f db b3 94 83 f9 90 27 36 55 57 df 3f 1e
0100: 21 27
Timestamp: 2017-02-10 23:35:11
Flags: 0x79
Beacon A:
OBC:
Boot count: 2030
Board temp 1: 20.0ºC
Board temp 2: 21.0ºC
Panel temps: [0.0, 20.5, 23.25, 9.0, 15.25, 25.75]ºC -
COM:
Bytes corrected by RS: 0
RX packets: 4
RX errors: 4
TX packets: 1369
Last temp A: 23ºC
Last temp B: 22ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.4V
Last TX current: 842mA
Boot count: 4546 -
EPS:
Boost converter voltages: [6.6160000000000005, 6.606, 0.0]V
Battery voltage: 8.298V
Current out: (73, 2, 98, 35, 5, 0)mA
Current in: (31, 44, 0)mA
Boost converter current: 28mA
Battery current: 102mA
Temperature sensors: (23, 23, 22, 22, 21, 21)ºC
Output status: 0x1d
EPS reboots: 0
WDT I2C reboots: 174
WDT GND reboots: 328
Boot cause: 8
Latchups: (0, 0, 0, 0, 0, 0)
Battery mode: invalid mode 3 -
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Average FPS 10sec: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last timestamp: 1970-01-01 00:00:00
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0 -
HUB:
Temp: 18ºC
Boot count: 890
Reset cause: 2
Switch status: 0xfc
Burn tries: (0, 0) -
ADCS:
Tumble rate: (3.473358154296875, 0.29575347900390625, -0.224761962890625)
Tumble norm: (4.468617916107178, 1.3056340217590332)
Magnetometer: (-308.4059753417969, 119.7243423461914, -143.16806030273438)
Status: 0x3
Torquer duty: (-85.0, -85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (76, 56, 12, 7, 4, 0, 0, 0)
