Regarding Observation 1122 …
Decoder gr-satellites GOMX-1
Frames 1.
- MESSAGE DEBUG PRINT PDU VERBOSE *
pdu_length = 258
contents =
0000: 1c 92 f8 7d ef ae c0 c2 90 ed f6 eb 2b 7e ed eb
0010: bf 16 ce 5a 97 66 cc 04 a2 83 3e 41 10 b6 88 94
0020: cd ea b1 fe 92 5e 81 21 1a f4 79 1c 59 27 58 06
0030: 6d c7 8d 75 26 af 90 5d 45 7e 5c 50 21 e7 11 2b
0040: 9b 5e 63 d0 20 3e 02 68 34 66 f2 fc b2 7d b6 f4
0050: dd ab 39 7f 5d e1 30 df 8a e9 f8 3c 03 d2 3e 53
0060: 37 aa 6a fb 08 72 04 d0 6b 85 e4 71 64 9d 6d 3d
0070: ba 36 71 d4 bb ee 61 95 13 f9 f0 50 87 8c 44 a6
0080: 6f 55 8f f4 80 ec 09 a0 d7 0b c8 e2 c9 3a da 7b
0090: 74 6c e5 a9 77 dc c3 2a 2b f3 e0 b1 0c 61 8b b0
00a0: de ab 1f e9 41 d6 be 41 11 b1 1c 45 ad d0 f7 76
00b0: a8 50 b4 e0 d0 a3 b0 52 94 57 82 c6 5d 2e 71 99
00c0: 7e 56 8c 79 00 72 8c 83 5c 6d 89 8b 24 a9 c3 ed
00d0: d1 91 b4 a0 9a 8e ce 1a af df 83 20 1e f4 c5 db
00e0: 58 6e 93 d0 18 b6 c1 7b 7a 53 bf f5 7e 5b 59 b6
00f0: 22 10 5e 4b d6 35 03 ba ed 70 ea 55 5c 10 df ce
0100: 69 cc
Timestamp: 2017-02-10 11:00:26
Flags: 0x69
Beacon A:
OBC:
Boot count: 2029
Board temp 1: 19.0ºC
Board temp 2: 20.0ºC
Panel temps: [0.0, 6.75, 13.5, 15.0, 18.75, 17.75]ºC -
COM:
Bytes corrected by RS: 0
RX packets: 0
RX errors: 0
TX packets: 579
Last temp A: 21ºC
Last temp B: 21ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.41V
Last TX current: 842mA
Boot count: 4544 -
EPS:
Boost converter voltages: [2.132, 2.104, 0.0]V
Battery voltage: 8.26V
Current out: (4, 2, 139, 45, 5, 0)mA
Current in: (420, 196, 51)mA
Boost converter current: 106mA
Battery current: 176mA
Temperature sensors: (21, 22, 21, 21, 20, 20)ºC
Output status: 0x1c
EPS reboots: 0
WDT I2C reboots: 173
WDT GND reboots: 328
Boot cause: 4
Latchups: (0, 0, 0, 0, 0, 0)
Battery mode: invalid mode 3 -
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Average FPS 10sec: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last timestamp: 1970-01-01 00:00:00
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0 -
HUB:
Temp: 16ºC
Boot count: 889
Reset cause: 2
Switch status: 0xfc
Burn tries: (0, 0) -
ADCS:
Tumble rate: (2.22930908203125, -1.3011932373046875, 1.2911224365234375)
Tumble norm: (4.296836853027344, 0.6023868322372437)
Magnetometer: (-352.5274658203125, 159.44921875, -128.7018280029297)
Status: 0x3
Torquer duty: (-85.0, 85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (5, 5, 253, 194, 178, 0, 16, 1)
