Regarding Observation 11189 …
Output from direwolf:
darkside@satnogs70:~/demod $ ./decode9600.sh /tmp/.satnogs/data/complete/satnogs_11559_2017-08-01T20-06-21.ogg
Dire Wolf version 1.4
Setting such a small audio statistics interval will produce inaccurate sample rate display.
Reading config file ax25_9600.conf
Audio input device for receive: stdin (channel 0)
Audio out device for transmit: null (channel 0)
Channel 0: 9600 baud, K9NG/G3RUH, , 48000 sample rate x 2.
The ratio of audio samples per sec (48000) to data rate in baud (9600) is 5.0
Increasing the sample rate should improve decoder performance.
Note: PTT not configured for channel 0. (Ignore this if using VOX.)
Ready to accept AGW client application 0 on port 8000 ...
Ready to accept KISS client application on port 8001 ...
Use -p command line option to enable KISS pseudo terminal.
Audio input level is too high. Reduce so most stations are around 50.
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00><0x02><0xa2><0xc0><0x00>\<0x87><0x90><0x01><0x00>g<0x8b><0x05><0x00><0x00>=@<0x00><0x00><0x00>~OPEN COSMOS~<0x00>q<0x09>df<0xea><0xff><0xb4><0xea><0xcd><0xd0>q<0xe9><0xd7><0xda>6E<0x83><0x81><0xad>"^<0xef><0xe2>Ts&<0xcb><0xc3>d<0x90>W!
dest '')" 0 c/r=0 res=0 last=0
source '')" 0 c/r=0 res=0 last=0
000: 4f 4e 30 31 53 45 00 4f 4e 30 31 53 45 00 03 00 ON01SE.ON01SE...
010: 02 a2 c0 00 5c 87 90 01 00 67 8b 05 00 00 3d 40 ....\....g....=@
020: 00 00 00 7e 4f 50 45 4e 20 43 4f 53 4d 4f 53 7e ...~OPEN COSMOS~
030: 00 71 09 64 66 ea ff b4 ea cd d0 71 e9 d7 da 36 .q.df......q...6
040: 45 83 81 ad 22 5e ef e2 54 73 26 cb c3 64 90 57 E..."^..Ts&..d.W
050: 21 !
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00>B<0xa9><0x0a><0x0a><0xf0><0x00><0x00><0x00><0x8a><0x10><0x03><0x04><0xbd>Gm<0x12><0x98><0xab><0xd9><0xde><0xd5>g<0x1b>q<0xc1>~Id<0xb7><0xbc><0xec><0xed><0xb0>9<0xfc><0x80><0xdc><0x80><0xbc><0x90><0xdb><0xec><0x03>\<0xaf><0xb4>i<0x17><0x97><0x13>8@
010: 42 a9 0a 0a f0 00 00 00 8a 10 03 04 bd 47 6d 12 B............Gm.
020: 98 ab d9 de d5 67 1b 71 c1 7e 49 64 b7 bc ec ed .....g.q.~Id....
030: b0 39 fc 80 dc 80 bc 90 db ec 03 5c af b4 69 17 .9.........\..i.
040: 97 13 38 40 ..8@
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00><0x02><0xa2><0xc0><0x00>z<0x87><0x90><0x01><0x00>g<0x8b><0x05><0x00><0x00>:@<0x00><0x00><0x00>~OPEN COSMOS~<0x00><0x12>w.g<0x09><0xb4><0xdf>K<0x86><0x96>%<0xf8><0x83><0x8f>|<0xf4>K<0xae>~Ac<0xae><0xfd><0x1a><0x1d>!G+<0xf0><0x84>m<0xe2>
010: 02 a2 c0 00 7a 87 90 01 00 67 8b 05 00 00 3a 40 ....z....g....:@
030: 00 12 77 2e 67 09 b4 df 4b 86 96 25 f8 83 8f 7c ..w.g...K..%...|
040: f4 4b ae 7e 41 63 ae fd 1a 1d 21 47 2b f0 84 6d .K.~Ac....!G+..m
050: e2 .
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00><0x02><0xa2><0xc0><0x00><0x84><0x87><0x90><0x01><0x00>g<0x8b><0x05><0x00><0x00>:@<0x00><0x00><0x00>~OPEN COSMOS~<0x00>tMu<0x09>t<0x00><0xd8>k?<0xe6><0x06><0x1e>r<0xf2><0xb1><0xb5><0x7f>wmS<0xb1><0x90><0x95><0xa8><0xab>Cn<0x91><0xb2><0xbd><0xef>P
010: 02 a2 c0 00 84 87 90 01 00 67 8b 05 00 00 3a 40 .........g....:@
030: 00 74 4d 75 09 74 00 d8 6b 3f e6 06 1e 72 f2 b1 .tMu.t..k?...r..
040: b5 7f 77 6d 53 b1 90 95 a8 ab 43 6e 91 b2 bd ef ..wmS.....Cn....
050: 50 P
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00><0x02><0xa2><0xc0><0x00><0x8e><0x87><0x90><0x01><0x00>g<0x8b><0x05><0x00><0x00>:@<0x00><0x00><0x00>~OPEN COSMOS~<0x00><0xb1>h<0xe9><0xee><0xba>t<0xa4><0xe3><0xde><0xbd><0xe3>r&<<0x1a><0x84><0xa2><0x89>D<0xdc><0x00><0xa4><0xa8><0x06><0x14><0x97>b<0x1d><0xee><0xf5><0x8d><0xfe>
010: 02 a2 c0 00 8e 87 90 01 00 67 8b 05 00 00 3a 40 .........g....:@
030: 00 b1 68 e9 ee ba 74 a4 e3 de bd e3 72 26 3c 1a ..h...t.....r&<.
040: 84 a2 89 44 dc 00 a4 a8 06 14 97 62 1d ee f5 8d ...D.......b....
050: fe .
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00><0x02><0xa2><0xc0><0x00><0x98><0x87><0x90><0x01><0x00>e<0xbb><0x05><0x00><0x00>:<<0x00><0x00><0x00>~OPEN COSMOS~<0x00><0xdb><0xa8><0xaa>y<0xf3><0xa4><0xcb><0x8d><0x02>k<0xce><0x12>J<0xe7><0xeb><0xf3>O<0xb8>|<0xea>4<0x8a><0xde><0xfe><0x10><0xb9><0x86><0x9f><0x93><0x8c><0xab><0x98>
010: 02 a2 c0 00 98 87 90 01 00 65 bb 05 00 00 3a 3c .........e....:<
030: 00 db a8 aa 79 f3 a4 cb 8d 02 6b ce 12 4a e7 eb ....y.....k..J..
040: f3 4f b8 7c ea 34 8a de fe 10 b9 86 9f 93 8c ab .O.|.4..........
050: 98 .
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00>B<0xa9><0x0a><0x0a><0xf3>Shell terminated<0x03><0x04><0xbd>Hm<0x12><0x02>f<0x8d><0x92>t<0xba><0xdb>zdGG<0xa0><0xaa><0xd2>-<0xee><0xbe><0xc6>_<0xa7>G<0x0b>m<0x00><0x18>U<0x8e><0x13>& <0xf7>X<0x80><0x1e>}<0xdf>
010: 42 a9 0a 0a f3 53 68 65 6c 6c 20 74 65 72 6d 69 B....Shell termi
020: 6e 61 74 65 64 03 04 bd 48 6d 12 02 66 8d 92 74 nated...Hm..f..t
030: ba db 7a 64 47 47 a0 aa d2 2d ee be c6 5f a7 47 ..zdGG...-..._.G
040: 0b 6d 00 18 55 8e 13 26 20 f7 58 80 1e 7d df .m..U..& .X..}.
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00><0x02><0xa2><0xc0><0x00><0xa2><0x87><0x90><0x01><0x00>e<0xbb><0x05><0x00><0x00>:<<0x00><0x00><0x00>~OPEN COSMOS~<0x00><0x8f><0xe8><0x98><0xff><0x19>7<0xed><0xcb><0x92><0x82><0xc7><0xd9><0x84><0x0d><0xfb><0xc7>C<0xe2><0x10>><0xf3><0xa3><0xc6><0xf3>t<0x84><0xaa>@<0xe8><0x83><0xc3><0x95>
010: 02 a2 c0 00 a2 87 90 01 00 65 bb 05 00 00 3a 3c .........e....:<
030: 00 8f e8 98 ff 19 37 ed cb 92 82 c7 d9 84 0d fb ......7.........
040: c7 43 e2 10 3e f3 a3 c6 f3 74 84 aa 40 e8 83 c3 .C..>....t..@...
050: 95 .
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00><0x02><0xa2><0xc0><0x00><0xac><0x87><0x90><0x01><0x00>d<0xbb><0x05><0x00><0x00>:<<0x00><0x00><0x00>~OPEN COSMOS~<0x00><0x99>><0xed><0x0c>+RC<0xe9><0x0d><<0xaf>E&z<0xf7><0xc2><0xcb>6v<0xda><0x09>^<0x11><0xeb><0xc0><0x90><0xd6><0xe6><0xf5>"<0xf2>O
010: 02 a2 c0 00 ac 87 90 01 00 64 bb 05 00 00 3a 3c .........d....:<
030: 00 99 3e ed 0c 2b 52 43 e9 0d 3c af 45 26 7a f7 ..>..+RC..<.E&z.
040: c2 cb 36 76 da 09 5e 11 eb c0 90 d6 e6 f5 22 f2 ..6v..^.......".
050: 4f O
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00><0x02><0xa2><0xc0><0x00><0xb6><0x87><0x90><0x01><0x00>d<0xbb><0x05><0x00><0x00>:@<0x00><0x00><0x00>~OPEN COSMOS~<0x00><0xc2><0xba><0x1d>#<0x96>Q<0xd3><0x18><0x94><0xef><0x8d>{<0x98>a<0xe4><0xa7><0x97><0xc7><0x08><0x02>Q<0x0e>8<0xbb>K<0xac><0x0b>}^<0x1e><0xef><0xa2>
010: 02 a2 c0 00 b6 87 90 01 00 64 bb 05 00 00 3a 40 .........d....:@
030: 00 c2 ba 1d 23 96 51 d3 18 94 ef 8d 7b 98 61 e4 ....#.Q.....{.a.
040: a7 97 c7 08 02 51 0e 38 bb 4b ac 0b 7d 5e 1e ef .....Q.8.K..}^..
050: a2 .
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00><0x02><0xa2><0xc0><0x00><0xc0><0x87><0x90><0x01><0x00>d<0xbb><0x05><0x00><0x00>:@<0x00><0x00><0x00>~OPEN COSMOS~<0x00><0xd6><0xcd>U<0x1e><0x05>i<0xf8><0xbc><0x06><0xd6><0xd5>v<0xec><0xf2><0x98><<0xb6>><0xa6><0xf8>}<0xae>z<0xfc><0xdb>o<0xd2><0x13>9<0x95>^<0xe5>
010: 02 a2 c0 00 c0 87 90 01 00 64 bb 05 00 00 3a 40 .........d....:@
030: 00 d6 cd 55 1e 05 69 f8 bc 06 d6 d5 76 ec f2 98 ...U..i.....v...
040: 3c b6 3e a6 f8 7d ae 7a fc db 6f d2 13 39 95 5e <.>..}.z..o..9.^
050: e5 .
[0] (Not AX.25)ON01SE<0x00>ON01SE<0x00><0x03><0x00><0x02><0xa2><0xc0><0x00><0xca><0x87><0x90><0x01><0x00>d<0xbb><0x05><0x00><0x00>:@<0x00><0x00><0x00>~OPEN COSMOS~<0x00><0x13><0xe8><0xc9><0xf9><0xcb><0x1d><0x84>4<0xe7><0x8d>0<0x1a><0xb8><3<0x0d>k<0xc0><0x8f>w<0xcc><0x9a>GRd<0xbb><0xde><0x9f>e<0xdd><K
010: 02 a2 c0 00 ca 87 90 01 00 64 bb 05 00 00 3a 40 .........d....:@
030: 00 13 e8 c9 f9 cb 1d 84 34 e7 8d 30 1a b8 3c 33 ........4..0..<3
040: 0d 6b c0 8f 77 cc 9a 47 52 64 bb de 9f 65 dd 3c .k..w..GRd...e.<
050: 4b K
