Regarding Observation 1065 …
Decoder gr-satellites.
Frames 25.
Timestamp: 2017-02-08 23:52:11
Flags: 0x79
Beacon A:
OBC:
Boot count: 2028
Board temp 1: 20.0ºC
Board temp 2: 22.0ºC
Panel temps: [0.0, 17.75, 20.75, 9.25, 14.25, 24.0]ºC -
COM:
Bytes corrected by RS: 0
RX packets: 3
RX errors: 3
TX packets: 1924
Last temp A: 23ºC
Last temp B: 22ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.35V
Last TX current: 842mA
Boot count: 4537 -
EPS:
Boost converter voltages: [7.405, 7.439, 0.0]V
Battery voltage: 8.298V
Current out: (73, 2, 150, 33, 5, 0)mA
Current in: (134, 26, 0)mA
Boost converter current: 112mA
Battery current: 127mA
Temperature sensors: (23, 23, 22, 23, 21, 21)ºC
Output status: 0x1d
EPS reboots: 0
WDT I2C reboots: 173
WDT GND reboots: 327
Boot cause: 4
Latchups: (0, 0, 0, 0, 0, 0)
Battery mode: invalid mode 3 -
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Average FPS 10sec: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last timestamp: 1970-01-01 00:00:00
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0 -
HUB:
Temp: 18ºC
Boot count: 887
Reset cause: 2
Switch status: 0xfc
Burn tries: (0, 0) -
ADCS:
Tumble rate: (-1.303253173828125, 3.115997314453125, -3.61480712890625)
Tumble norm: (4.400343418121338, 0.5766730308532715)
Magnetometer: (-355.7172546386719, 145.6975555419922, -140.91937255859375)
Status: 0x3
Torquer duty: (85.0, -85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (5, 5, 121, 250, 5, 0, 0, 0)
