Regarding Observation 103124 …
I don’t think I see anything, except noise?
Exactly!
This observation has been vetted wrong.
Fixed it to “bad” just now. Thanks for spotting!
Some is very subjective as there could be a signal from another satellite or interference or CW instead of BPSK or FSK. As soon as all the sats can be decoded it will add an extra level of good or we can call perfect
A bandscan of 70cm revealed that the present JSpOC TLE of object 43188/2018-014J is consistent with transmissions at 435.95 MHz. DK3WN has objects 43186 through 43189 as S-net A, B, C and D, all transmitting 1k2 FFSK at 435.950 MHz.It would be great of the database can be updated with these objects/frequencies.
Changes are in db and network!
