Thank you for the info!
I’ve changed the NORAD ID that is followed for DESCENT to be 46927 and I’ve scheduled a couple of observations to check if we can get any signal from the satellite and identify it.
@frenchbazou do you know if there are any observations that prove DESCENT is 46927 or how CelesTrak identified the object?
A related comment I did some time ago in this thread:
A comment about the temporary NORAD IDs and how we change these. As currently there isn’t any source of truth about them, for changing a NORAD ID of a satellite we should have one of these:
- Observations that show that the satellite follows that NORAD ID
- Identified all the other satellites of the same deployment with the 1st method, so the remaining is the satellite.
@cgbsat @pierros maybe you can check your latest strf observations for any sign of DESCENT that follows 46927 at 435.775 MHz.
