I don’t know what is happenning with my satnogs… Since last updating SOME observations have audio and others don’t have…
https://network.satnogs.org/observations/?station=342
I tried with different sample rate, but no success.
Any idea?
Any idea?
I realized that is failing (no audio recorded) on FM observations.
Please, I need some help
journalctl -f -u satnogs-client.service
– Logs begin at Thu 2019-02-14 10:11:59 GMT. –
Feb 29 23:42:29 raspberrypi satnogs-client[319]: return request(‘put’, url, data=data, **kwargs)
Feb 29 23:42:29 raspberrypi satnogs-client[319]: File “/usr/lib/python3/dist-packages/requests/api.py”, line 60, in request
Feb 29 23:42:29 raspberrypi satnogs-client[319]: return session.request(method=method, url=url, **kwargs)
Feb 29 23:42:29 raspberrypi satnogs-client[319]: File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 533, in request
Feb 29 23:42:29 raspberrypi satnogs-client[319]: resp = self.send(prep, **send_kwargs)
Feb 29 23:42:29 raspberrypi satnogs-client[319]: File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 646, in send
Feb 29 23:42:29 raspberrypi satnogs-client[319]: r = adapter.send(request, **kwargs)
Feb 29 23:42:29 raspberrypi satnogs-client[319]: File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 498, in send
Feb 29 23:42:29 raspberrypi satnogs-client[319]: raise ConnectionError(err, request=request)
Feb 29 23:42:29 raspberrypi satnogs-client[319]: requests.exceptions.ConnectionError: (‘Connection aborted.’, timeout(‘The write operation timed out’))
There were some updates today, can you make sure that you are in the latest version. Also is this persistent after reboot?
I’ve made several reboots, testing with different rates, but always the same.
I’m going to update …right now
Thanks
If it fails again, please open an issue at https://gitlab.com/librespacefoundation/satnogs/satnogs-client/issues
Updated with satnogs-client-1.1 and gr-satnogs_2.0.1-1
Let’s see next observations…
With the new update is still the same…No audio on FM observations
I’ve just opened a new issue on Gitlab
Thanks
I’ve just realized that is only uploading Low elevation FM passes (short passes).
Makes sense…
With the new client version 1.1.2 now is fixed
Many thanks
