Hello, I am a newbie. I have setup Pi and SDR as instructed all is well and showing in test mode on the network, but I am not capturing any data. I have entered config advanced and this is the result of the support file, I do not understand the errors, could you give me some advice please, Is it possible to display wether the SDR is receiving any data please.
File “/usr/lib/python3/dist-packages/apt/cache.py”, line 90, in enter
return self._lock.enter()
apt_pkg.Error: E:Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
During handling of the above exception, another exception occurred:
File “/var/lib/satnogs-config/bin/satnogs-config”, line 8, in
sys.exit(main())
File “/var/lib/satnogs-config/lib/python3.7/site-packages/satnogsconfig/init.py”, line 29, in main
menu.show()
File “/var/lib/satnogs-config/lib/python3.7/site-packages/satnogsconfig/menu.py”, line 258, in show
self._typesmenu[‘type’]
File “/var/lib/satnogs-config/lib/python3.7/site-packages/satnogsconfig/menu.py”, line 478, in _support
).dump(indent=4) +
File “/var/lib/satnogs-config/lib/python3.7/site-packages/satnogsconfig/helpers/support.py”, line 87, in dump
return json.dumps(self.info, *args, **kwargs)
File “/var/lib/satnogs-config/lib/python3.7/site-packages/satnogsconfig/helpers/support.py”, line 66, in info
“pending-updates”: apt.has_updates(),
File “/var/lib/satnogs-config/lib/python3.7/site-packages/satnogsconfig/helpers/apt.py”, line 16, in has_updates
cache.update()
File “/usr/lib/python3/dist-packages/apt/cache.py”, line 567, in update
with _WrappedLock(apt_pkg.config.find_dir(“Dir::State::Lists”)):
File “/usr/lib/python3/dist-packages/apt/cache.py”, line 93, in enter
(self._path, e))
apt.cache.LockFailedException: Failed to lock directory /var/lib/apt/lists/: E:Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
pi@raspberrypi:~ $
It looks like it doesn’t have access to get the lock needed for generating the report. My guess is that instead of sudo satnogs-setup you ran just satnogs-setup. Let us know if your issue is solved by running sudo satnogs-setup.
I just started experiencing this lock error also. Everything was running fine, rotctld and rigctld. Noticed my inexpensive rtl-sdr frequency was off so used GQRX to find the PPM Error (53). So I used sudo satnogs-setup to adjust Advanced > Radio > SATNOGS_PPM_ERROR intially to 53.0 and exited. After doing this no more observations. journalctl logs showed no activity. I reset this then to 53, same issue, then removed the SATNOGS_PPM_ERROR entry all together. Still no observations. Now when I run sudo satnogs-setup and ask for Support I get the same error
File “/user/lib/python3/dist-packages/apt/cache.py”, line 90 in__enter__ return self._lock._enter()
apt_pkg.Error: E:Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarly unavilable)
It looks like there is a file lock somewhere, not a permission issue.
A second lock error is also reported, this time on a directory /var/lib/apt/lists
It looks like that something broke when satnogs-setup was updating. Try to remove manually the lock by running:
sudo rm /var/lib/apt/lists/lock
After that try running again satnogs-setup, update and then apply changes. Just in case, every time you change a value like SATNOGS_PPM_ERROR, you need to hit apply and then exit from satnogs-setup.
