## Soapy SDR -- the SDR abstraction library ##
Probe device
[INFO] [UHD] linux; GNU C++ version 8.3.0; Boost_106700; UHD_3.15.0.0-2
RtApiAlsa::getDeviceInfo: snd_pcm_open error for device (default), No such file or directory.
-- Device identification
driver=Airspy
hardware=Airspy
device_id=0
origin=https://github.com/pothosware/SoapyAirspy
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
* Bias tee - Enable the 4.5v DC Bias tee to power SpyVerter / LNA / etc. via antenna connection.
[key=biastee, default=false, type=bool]
* Bit Pack - Enable packing 4 12-bit samples into 3 16-bit words for 25% less USB trafic.
[key=bitpack, default=false, type=bool]
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS16, CF32
Native format: CS16 [full-scale=32767]
Antennas: RX
Full gain range: [0, 45] dB
LNA gain range: [0, 15] dB
MIX gain range: [0, 15] dB
VGA gain range: [0, 15] dB
Full freq range: [24, 1800] MHz
RF freq range: [24, 1800] MHz
Sample rates: 6, 3 MSps```
Error in rate test: SoapySDR::Device::make() no match
Ah-ha, if I run: $ sudo -u satnogs SoapySDRUtil --args="driver=airspy" --direction=RX --rate=3e6
[INFO] Using format CS16.
Stream format: CS16
Num channels: 1
Element size: 4 bytes
Begin RX rate test at 3 Msps
Starting stream loop, press Ctrl+C to exit...
2.99073 Msps 11.9629 MBps
The issue here appears to be that SoapySDRUtil --probe is showing driver=Airspy whereas the setting actually needs to be driver=airspy (no capitals).
I guess this is something that needs to be fixed in SoapyAirspy.
