I finally made it work, however there is something that probably I don’t quite understand; not sure if it’s a bug or my comprehension of what the test mode is.
When I switched the antenna and update the station configuration I placed the station in test mode until I can evaluate the change.
With my station in test mode (figure attached) I’m unable to schedule passes.
Placing back the station as online that restriction dissapear, and now I’m able to schedule observations.
My understanding of the test mode is the station owner is able to perform observations while on it but other observers aren’t.
Yes, I’m logged as the station operator as you can see in the “avatar”.
In the first screenshot you need to select (by clicking on them or in the “All” button) the observations to schedule. As none observation is selected, the schedule button is disabled.
The non-selected observations is result of the station being in testing mode, you can override this by following this link https://network.satnogs.org/observations/new/?ground_station=499 in this link you set that you want this specific station, so by default all the observations, even if it is in testing mode, are selected.
Alternatively you can go on your station page and schedule observations from there.
hm… the concept is that the icon shows what the button does… maybe in a future change of UI the text will be omitted. There is an issue for showing how many observations are selected/are going to be scheduled, this will clear up any confusion when implemented. Thanks for the feedback!
