Need some advice on the telemetry and ground station for our next balloon flight
Hey everyone!
I’m a student working on high-altitude balloon projects. We’ve already flown one mission, and now we’re looking at improving our telemetry and ground station for the next flight.
We’re looking into the 435–438 MHz range for telemetry, but I’m still trying to understand what rules apply to a balloon project in India, especially transmit power and whether we’d need any licence or other permission. I’d like to get this clear before choosing the radio.
For our next flight, we’re considering an altitude of around 50 km, with the balloon potentially drifting a few hundred kilometres from the ground station depending on the winds. At that distance, the balloon could be very low on the horizon, so I’m curious how practical a reliable radio link would be with a student-built setup.
For the ground station, we’re considering a QFH antenna on the balloon and a directional antenna on the ground. I’ve also been looking at the SatNOGS rotator project to see if we could use the balloon’s GPS coordinates to track it automatically.
One thing I’m unsure about is how to deal with real flight conditions. If we start missing packets or lose GPS updates for a while, how should the ground station handle that? And how do we know whether the problem is the radio link, antenna pointing or something else?
If anyone has worked on similar setups, I’d love to hear how you approached them, or if there are existing projects or documentation worth learning from.
We’re working with a student budget, so advice from people who’ve tried this in practice would really help us make better decisions before committing to hardware.
Thanks for reading!
check this post bro. maybe can give you some inspiration
Hi and welcome.
I have no idea about the rules fro flying a balloon in India, neither for the airborne transmissions in a frequency range (435 - 438 MHz) assigned to satellite transmissions (with or without a radio amateur license)
I find 50 km quite optimistic for a balloon. We had the highest altitude in the EU with a bit over 41 km , that required a 1200 gram balloon and over 2 m3 HE, you allready need 1.2 m3 to lift the balloon.
You don’t mention what type of payload and if you plan / require to recover the remains.
At 50 km altitude your reception range would be huge. For example, 20 mW TX power, at 17 km altitude, and descending, still has 460 km RX range
Image from a flight this morning, you can check in on amateur.sondehub.org what’s in the air, and what the reception range is at certain atltitudes.
My (our) balloons are usually running on 2 Energizer batteries (proven to work up to minus 40 degrees) or solar and transmit 20 mW. Antenna is usually just a 1/4 wave wire, sometimes with the same size ground wire about 90 degrees away from the (vertical mounted) transmit antenna.
For the GPS (ATGM336h is our favourite) we fly with 47 mm wire as antenna.
If the GPS is missing to receive coördinates (bad RX, or jamming) the decoder software should handle that as last position and altitude kept till update, otherwise if you upload zeroes to the map your balloon would be on a map somewhere in an ocean.
Try to find some local radio club to see if you can add listeners / receivers to your balloon project.
I have tried to support another student project about 2 years ago on a discord group, but they ran into the first problem that HE costed a fortune to lift a 1200 gram balloon so that one never went up.
Good luck !
Ben
I did take the opportunity to ask Claude weather 50 km would be realistic. Below are the results:
For a school project, 50 km isn’t a realistic target with a latex balloon. It has been reached, but only by professional plastic-film balloons.
The physics:
Altitude Air pressure (standard atmosphere)
40 km ≈ 2.9 hPa
50 km ≈ 0.8 hPa
Between 40 and 50 km the pressure drops by a factor of about 3.6. A balloon that has just reached 40 km would have to expand to 3.6 times its volume, about 1.5 times its diameter, to get to 50 km. Latex can’t stretch that far. Even the largest common latex balloons (3000 g) are specified to burst at roughly 38–40 km. The best latex flights I know of reached the low-to-mid 40s, after careful work: little lift for a slow ascent, a fresh balloon, and luck with the temperatures.
So your 40.3 km on a 1200 g balloon is excellent. A 1200 g balloon is normally specified to burst at about 33 km, so you got far more out of it than the datasheet promises.
How 50 km has been done: with thin plastic (polyethylene) balloons that don’t stretch at all. They’re launched as a long, mostly empty “sock” and only fill out completely high up. The current altitude record for an unmanned balloon is 53.7 km, set by Japan’s JAXA in 2013 (BS 13-08), using film thinner than a garbage bag. That takes a professional launch team, special equipment and a lot of money.
If they are serious about it, India has its own professional facility: the TIFR Balloon Facility in Hyderabad, which flies large plastic science balloons. A school project could perhaps fly a payload with them.
My advice for the students: aim for 35–40 km with a large latex balloon (2000–3000 g). That’s already very ambitious and reaches the “black sky” region. Your own flight is the perfect example to share with them.
Sources:
Hey Ben, sorry for the late reply, college exams got in the way and I kept thinking I’ll reply once I get some time.
Thanks for sharing all this. We’ve been checking SondeHub and other balloon flights too, so yeah I get your point about the reception range. The 50 km is more of an upper end case we’re designing around, we know getting there with a latex balloon is a differnt story altogether.
One thing I really want to do with this project is build a proper ground station for our team. We dont really have the setup to reliably recieve data from a moving payload yet, so understanding how the communication behaves during an actual flight is a big part of the project for me.
We’re looking at the TI CC1200 at around +14 dBm. For power we’re considering 3 Energizer lithium AA cells instead of 2, mainly because of the spectral sensor and the rest of the electronics. We’ve calculated the power budget for the complete payload and have around 20% margin for now. But thats still on paper, we’ll need to test it under actual load and cold conditions.
We definitely want to recover the payload too, the sensors are not cheap enough to just wave goodbye to them. Your point about keeping the last valid GPS position is really useful, otherwise our balloon might randomly end up in the ocean on the map just because it missed a GPS update.
We’re still figuering out the antenna side. We were thinking about a quarter-wave wire, but also looking at a QFH because the payload can rotate. Not sure if using both is worth the extra complexity or if we should put more effort into the ground station itself.
In your flights, have you noticed many dropouts because of payload rotation with the quarter-wave antenna, or has it been reliable enough in practice? Also, if you were starting a ground station on a student budget, would you first improve one receiver with a good antenna or try getting a few simpler receivers at different locations? I’m trying to understand where the effort would make the biggest diffrence.
We’ll try looking into local radio clubs too, we’re pretty much starting from scratch with the receiver network so your suggestion makes sense. Also, which exact Energizer batteries do you use? Would be useful to know since we’re trying to figure out the cold weather side of things as well.
Thanks again Ben, really appreciate you sharing the practical side of it. A lot of this looks straightforward in calculations until you actually have to make it work in flight.
Thanks for mentioning TIFR! I’d looked them up earlier, but getting a student payload flown through them doesn’t seem that straightforward from what I read. Still, we’ll try contacting them and see what they say.
We did find PAWAN in Pune, who manufacture meteorological balloons commercially, so we’re looking into that route too. Getting the balloon is one thing, figuring out the rest of the logistics is another!
Hey bro, sorry for the late reply,
This is actually pretty intersting! I was looking more into the communication and licensing side, didnt really think much about image transmission before.
Our payload is collecting 18-band solar spectral data every second along with GPS, altitude, pressure, temperature, humidity and orientation. We’re planning to store the full dataset onboard on an sd card with timestamps, and send the important telemetry over radio. Sending everything over the link would probaly be too much, so we’re still figuring out what data is actually worth transmitting during flight
Since we’re also trying to build our own ground station, I was curious how SSDV handles missing packets and if packets recived by different stations can be combined to recover more of an imsge, I guess we have a similar problem with not losing important telemetry when reception gets weak
I saw your comment about SSDV over LoRa for the next satellite, have you looked into how it could work yet or is it still just an idea?! Curious how much data rate you can actually get and whether multiple ground stations make a big difference when some packets dont get through
a good 1/4 wave vertical omnidirectional has a radiation pattern with close to no “nulls”
The explanation, as found on the internet for your “question”
1. Side view:
  • Radiation is strongest toward the horizon and falls off slowly downward. It’s −1 dB at 30° below horizontal and −2.6 dB at 45°.
  • The only real weak spot is straight down, along the whip. That’s −10 dB at 15° from vertical and −20 dB at 5°.
  • The two curves overlap. One is the vertical plane through two radials, the other is between them. That’s the first sign that turning the payload changes nothing.
2. Top view, answering the rotation question:
  • The pattern is a circle at every downward angle. The calculated variation is less than 0.05 dB at 5°, 20° and 45° below horizontal.
  • The radiating part is the vertical whip, which is round. The four radials mostly cancel each other’s radiation.
3. Does the weak spot below matter? No. This panel combines the pattern with distance for a balloon at 30 km:
  • Stations near the point under the balloon are very close, 30 to 40 km away instead of hundreds. That makes up for the weak spot.
  • The strongest signal lands 10 to 100 km from the point below, about 15–20 dB above a station 600 km away.
  • Only within about 2 km of the point directly below does the signal drop below that of the distant station, and even there it’s easily receivable.
The point about recovery is clear, That also makes me suggest you do not only transmit the values of the sensors but also log them on some memory card during flight. That makes you not completely dependent on the receiving stations to get as much data as possible but gives you a complete logging after recovery of the payload.
3 batteries is ok, depends a bit what your transmitter model expects for power, but you can easily grab 3 volt from the interconnection between battery 2 and 3 if necessary.
You asked about the type: https://data.energizer.com/pdfs/l91.pdf
There are environment improved Energizers, which advertise with recycled materials, they have the same capacity but only at -20 degrees, dropping 50 percent at -40 degrees which I wouldn’t take the risk.
A QFH beneath your tracker gives the advantage that you have better reception when below the payload, but 3 to 6 dB less reception on “the horizon” where you need your receivers to show the signals. It’s larger, more difficult to build and gives more windload when flying.
If you are in the design phase of the tracker, low TX power when above 1000 meter (13 dBm would be enough) and have it detect when < 1000 meter and change the TX power to 20 dBm which makes tracking in the field less difficult. Edit: Also decreasing the TX interval below 1000 m altitude would be great, you get a position update more often that way.
Are you familiar with the path prediction on sondehub ?
That’s it for now :slight_smile:
you should check this link bro
