I have verified my config
SATNOGS_STATION_ID 113
SATNOGS_API_TOKEN 42… 59 (the same as was issued to me)
SATNOGS_NETWORK_API_URL https://network.satnogs.org/api/
I’ve just checked by running the api request with your api key and station id as it is run by the client and I got an answer.
+1 on what @DL4PD suggested. Check the api key again, check that there are not spaces or hidden characters on api token at the beginning or at the end.
EDIT: My request made your station look online… it will get offline after some time passed without a new request.
@DL4PD Fredy, Patrick
I made a typo, having to enter the API key manually.
Putty does not allow me to copy and paste into the setup form. It did help to take a text editor and put the API key on the first line and then after doing the setup to read the result from http://:5000/configuration/ and copying the result from SATNOGS_API_TOKEN underneath.
Corrected the typo. Notice it changed from Red to Orange [Testing]
Next step – make an observation.
