I am trying to figure out the difference between the version I am currently building (which has the IR sensor): https://satnogs.org/documentation/projects/ - this shows a pic of the version that I am currently trying to build up (has the IR sensor).
At first glance with the CAD drawings it appears that the only differences between the two sets of hardware is the end stop bracket, and two gears…Is that correct?
There’s also a motor mount and the sprocket is different to work with the mechanical endstop. Believe the worm gear goes together a little differently in 3.1, same parts though on the work gear
Not created yet. 3.1 isn’t officially released yet. But are encouraged to build it and contribute to creating the instructions and docs. I’ve took pics in various stage of my build, was gonna eventually post with some instructions after I got mine together and working
So how are we supposed to piece this hardware together? They’ve release the V2.0 PCB (at least it is on the website), but the documentation is next to impossible to find…where is the info for the end stop switch?
So, what is the process to add to the write-up to hep with clarity and such. Also, I have updated the rotor_pins.h file that is on the repository is NOT correct. I finally just took the file, modified and am using it now. How do I get that file to “someone” to incorporate into the current release?
Here is my version of the file that corresponds exactly with the schematic V2 dated 2018-01-2.
