I have a local LTE operator in the frequency range 462,5-467,5 MHz. MHz, so all observations like SARAL and METOP-A turns out bad.
Is there a way to limit the frequency range of a station?
Even - station #987
Even - station #987
You’ll have to build/buy a filter.
–Roy
K3RLD
If you mean to limit the frequency range within which transmitters can be scheduled, you can select different antenna types. The UHF Lindenblad and UHF Eggbeater have frequency ranges of 430 to 440MHz. The name of the antenna type is purely informative, as only the frequency range is used for SatNOGS operations (scheduling primarily).
I´m thinking of a limit so others will not schedule observations within this range on my station.
I can add a filter but the observations within this range will not work since the LTE station is close.
Ah, gotcha. Admins will need to create a new “antenna” for you, I think (at least until any new frequency selection features are added).
–Roy
Thank you for answers. I have now set my station antenna to UHF Lindenblad.
-Even
