I did a longer mental note on lightning issues which can occur with your groundstation.
http://space.pub/2015/03/building-a-satnogs-groundstation-grounding-and-lightning-protection
As a result I think I will implement an diode rectifier and some capacitors so that you can directly connect an isolated transformator in the next revision. Opinions on that?
