Note 1: Some of the above used TLE are not necessarily mean identification for the satellites. Be careful! Note 2: If something is missed or changed, let me know to fix it
Over the past few days of communication, we noticed that the angular momentum of our satellite has been gradually increasing, even though the ADCS has been powered off.
To analyze the cause, we started downlinking the system logs yesterday using our ground station in Korea. However, since we need to downlink all the logs accumulated since launch, we expect this to take several weeks. While the system logs are being downlinked, our Korean ground station cannot receive beacons, so we would greatly appreciate your help with observations.
Currently, there are no remaining observation schedules for our satellite, and beacon observations have stopped. If possible, we would be grateful if you could create observation schedules for GBSAT.
Also, if you have received a GBSAT beacon but have not yet received your eQSL card, please contact us and we will gladly send one to you.
Thank you so much for your continued support.
This is most resent TLE of GBSAT from NORAD.
We found that satellite was not sending beacon since 1 day after last telecommand due to reboot roop. However, we send a mode change command and it might be fixed. Thank you for notice that there was no signal.
