KSLV-2 Launch Planned : 2026-10-07 03:25 UTC
Thank you Isaac for your detailed reply and link to all necessary information.
Would you like me to do a merge request for your .ksy decoder for SatNOGS?
Daniel
I believe this is the launch livestream:
https://www.youtube.com/watch?v=v9gY7VkVT0w
super!
alternative_names:
  - CPSAT1
norad: 98194
  &tlm Telemetry:
    telemetry: ax25
  9k6 BPSK downlink:
    frequency: 437.265e+6
    modulation: BPSK
    baudrate: 9600
    framing: AX.25 G3RUH
    - *tlm
gr_satellites CPSAT.yml --wavfile CPSAT_audio_48k.wav --hexdump
((transmitter . 9k6 BPSK downlink))
pdu length =        184 bytes
pdu vector contents =
0000: 86 a0 a6 82 a8 62 e0 86 a0 a6 82 a8 62 61 03 f0
0010: 09 03 c0 0b 00 a1 57 f7 32 8a 84 bd 00 00 00 00
0020: 01 01 01 00 00 fe 00 00 ff 0c cf 00 00 00 00 80
0030: 00 07 ff ff ff ff ff ff ff ff ff ff ff ff 00 00
0040: 00 00 00 00 0a 01 02 03 04 05 06 07 08 09 0a 00
0050: 00 00 00 00 00 00 00 02 6d 03 21 00 ff ff ff ff
0060: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0070: ff ff ff ff 01 00 00 00 00 00 00 00 00 00 00 00
0080: 00 00 80 05 00 00 00 00 00 00 ff 7f 00 00 00 00
0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00a0: 3b 0b 00 00 ff ff ff 00 00 01 00 00 00 01 00 1f
00b0: 00 00 00 00 00 00 ff ff
norad: 98243
  &tlm Telemetry:
    telemetry: ax25
  9k6 GFSK:
    frequency: 435.95
    modulation: FSK
    baudrate: 9600
      - *tlm
GBSAT
1 98243U          26280.14583333  .00000000  00000-0  50000-4 0    06
2 98243  97.7500 370.4500 0001433   0.0000 145.1000 14.89340176    00
https://forum.nasaspaceflight.com/index.php?topic=65471.0
Naro, Korea:
Latitude: 34.4316,
Longitude:127.5344
launch = 2026-10-07T03:25:00 UTC
not sure if correct, based on previous launch
inclination = 97.75
SSO = ~600km
direction: south
norad: 98243
5 menit
faketle -n 370.45 -m 145.1 -q 599 -Q 601 -I 97.75 -t 2026-10-07T03:25:00 -d 300 -i 98243U > fake-gbsat.txt && satorbit -c fake-gbsat.txt -q -t 2026-10-07T03:30:00 -B 34.4316 -L 127.5344
update with latest valid information from @isaac44
faketle -n 370.54 -m 145.1 -q 569 -Q 571 -I 97.6704 -t 2026-10-07T03:25:00 -d 300 -i 98243U > fake-gbsat.txt && satorbit -c fake-gbsat.txt -q -t 2026-10-07T03:30:00 -B 34.4316 -L 127.5344
GBSAT
2 98243  97.6704 370.5400 0001439   0.0000 145.1000 14.98996526    07
I am much appreciated for your active support. Can you also add fake TLE for SLEDGE before launch? I’d like to user SATNOGS for initial beacon signal if possible.
Once we have orbital element from the launcher, we’ll post out estimated TLE calculated from orbital element.
This is my take on TLE using all the info I can find online and in this thread, TLE for launch time 2026-10-07T03:25Z:
GBSAT
1 98243U          26280.14444444  .00000000  00000-0  50000-4 0    05
2 98243  97.6704  10.0320 0003597   0.0000 145.0950 14.98187870    08
SLEDGE
1 98241U          26280.14444444  .00000000  00000-0  50000-4 0    03
2 98241  97.6704  10.0320 0003597   0.0000 145.0950 14.98187870    06
UEL-Y-SYS
1 98198U          26280.14444444  .00000000  00000-0  50000-4 0    04
2 98198  97.6704  10.0320 0003597   0.0000 145.0950 14.98187870    07
BEE-1012
1 98197U          26280.14444444  .00000000  00000-0  50000-4 0    03
2 98197  97.6704  10.0320 0003597   0.0000 145.0950 14.98187870    06
SD-1_SAT
1 98196U          26280.14444444  .00000000  00000-0  50000-4 0    02
2 98196  97.6704  10.0320 0003597   0.0000 145.0950 14.98187870    05
DAEJEONSAT-1
1 98195U          26280.14444444  .00000000  00000-0  50000-4 0    01
2 98195  97.6704  10.0320 0003597   0.0000 145.0950 14.98187870    04
CPSAT
1 98194U          26280.14444444  .00000000  00000-0  50000-4 0    00
2 98194  97.6704  10.0320 0003597   0.0000 145.0950 14.98187870    03
PS either using @bali’s ones or mine it should not make any big difference as both are very close for a pre-launch TLE estimation.
Sats are being deployed, so I’m setup for SLEDGE, GBSAT, & CPSAT when they pass over the Eastern U.S. here in a bit.
Deployment above Banda Sea with East Nusa Tenggara Island and Australian continent visible.
SLEDGE
1 99999U          26280.15383156  .00000000  00000-0  22504-3 0  9991
2 99999  97.6615  16.3360 0011381  84.5637 100.4418 14.97738215    02
This initial TLE generated from separation vector. This shall be used until spacetrack have updated TLE.
Ok, nothing from SLEDGE, unfortunately, but GBSAT & CPSat appear to be up & running. I will replay to see about some decodes.
Observed signals were 2 to 3 minutes LATER than the preliminary TLE indicated. Plan accordingly until we see the TLEs recalculated.
This initial TLE generated from separation vector that can be used meanwhile.
CPSAT
1 98194U          26280.15371675  .00000000  00000-0  50000-4 0    06
2 98194  97.6560  16.3340 0021245 100.2531  84.1477 14.95702602    06
Changed to use the temporary NORAD ID in DB
SLEDGE
1 98241U          26280.15383156  .00000000  00000-0  22504-3 0  9990
2 98241  97.6615  16.3360 0011381  84.5637 100.4418 14.97738215    01
Based on UEL-Y-Sys observation here is the TLE:
UEL-Y-Sys
2 98198  97.6704  19.7088 0003597   0.0000 134.9051 14.98187870    03
And here is the same TLE used for the rest of the satellites:
GBSAT
2 98243  97.6704  19.7088 0003597   0.0000 134.9051 14.98187870    04
BEE-1012
2 98197  97.6704  19.7088 0003597   0.0000 134.9051 14.98187870    02
SD-1_SAT
2 98196  97.6704  19.7088 0003597   0.0000 134.9051 14.98187870    01
DAEJEONSAT-1
2 98195  97.6704  19.7088 0003597   0.0000 134.9051 14.98187870    00
Not perfect TLE but it follows much better the satellites than the initial.
As the TLE is changed kind of a lot, I’m going to re-schedule some of the future observations.
Sorry - while both GBSAT & CPSat appeared to have some packets that should have been strong enough to decode, it’s really tough on replay to be precise enough when such a large sample rate was used (to see both signals in the same waterfall).
So, if they haven’t already, someone else will get to enjoy the first decodes from those sats. But it sure was nice to see what certainly appeared to be downlink packets from both of them. At least for now, I can’t confirm that it actually was packets from those specific sats.
@onbspace unfortunately in observation like this the signal is one of the NANOFF A or NANOFF B satellites. You can see one of their observations here.
I believe this is a good pair of GBSAT decodes:
https://network.satnogs.org/observations/15142966/
For GBSAT we have some first decodes in https://network.satnogs.org/observations/15142966/.
EDIT:
You got me :slight_smile:
So for now we have seen signals from:
GBSAT
CPSat
UEL-Y-Sys and/or BEE-1012 and/or SD-1_SAT
and a big maybe from SLEDGE
About UEL-Y-Sys, BEE-1012 and SD-1_SAT we will need some sample demodulated frames to compare with the ones we have in Network’s observations in order to make clear who is/are the one/ones we received.
Observation 15143902
This looks the first signal observation of SLEDGE, we’re working on decoding now.
For me it looks like matching frequency and modulation with doppler offset potentially from wrong TLE.
FYI, SLEDGE send beacons every 60seconds by default.
