Hello @bali,
I’m working on a decoder for telemetry transmitted by JY1Sat (43803) and am currently trying to understand and document its telemetry format.
I’ve been analyzing observations available through the SatNOGS database and have managed to extract and reconstruct valid telemetry frames from the received data. From this analysis, I’ve also been able to identify parts of the frame structure and decode a number of parameters, including values related to battery voltage, bus voltage, and system counters.
Before I go much further, I’d like to verify that the interpretations I’m making are actually correct rather than relying entirely on reverse-engineering.
Is there an official telemetry document, protocol description, or technical specification available for JY1Sat that describes the frame layout, telemetry fields, data types, scaling/conversion factors, or sensor mappings?
Having access to the original specification would allow me to cross-check the fields I’ve identified and make sure the decoder produces accurate results. My goal is to eventually have a reliable decoder that can also be useful to other members of the satellite/SDR community.
If the documentation is available publicly, I’d really appreciate it if you could point me in the right direction.
Thanks for your help.
Best regards,
Sunil
