pu4elt
September 22, 2026, 4:39pm
1
"SSTV Event Incoming!
ARISS SSTV Series 33 will feature images focused on student education, transmitted from the International Space Station October 2-6.
This special Expedition 75 SSTV event is just 9 days away. Get your SSTV software and decoders ready!"
Post made by ARISS on Twitter/X. See HERE
Good luck to everyone !!
fojtp
October 2, 2026, 7:16am
2
Bump.. The event is starting soon.
She’s started, best of luck to everyone.
BG2GFC
October 2, 2026, 10:54am
4
Very strong signal in 4.8°
fojtp
October 2, 2026, 11:36am
6
Something went wrong..
satnogs-3677 | INFO satnogsclient.observer.observer Begin observation 15105148 ...
satnogs-3677 | INFO satnogsclient.radio.grsat Starting gr_satellites for observation 15105148 at 66560 sps
satnogs-3677 | INFO satnogsclient.observer.observer Start gnuradio thread.
satnogs-3677 | ZMQ IQ SUB Connecting to 127.0.0.1:16888
satnogs-3677 | ZMQ audio SUB Connecting to 127.0.0.1:16889
satnogs-3677 | rig_check_rig_caps: p1=0x7f97330640, p2=0x7f97336bc0, rig_model=0x7f97330640, macro_name=0x7f97336bc0
satnogs-3677 | initrigs4_dummy: _init called
satnogs-3677 | rig_init: rig_model=Hamlib NET rigctl
satnogs-3677 | rig_init: rx_range_list1 is empty, using rx_range_list2
satnogs-3677 | rig_init: rig does not have tx_range!!
satnogs-3677 | netrigctl_init version 20230106.0
satnogs-3677 | Found Rafael Micro R828D tuner
satnogs-3677 | RTL-SDR Blog V4 Detected
satnogs-3677 | usb_claim_interface error -6
satnogs-3677 | [INFO] Opening Generic RTL2832U OEM :: 00000007...
satnogs-3677 | len(audio_taps) = 65
satnogs-3677 | [INFO] Using format CF32.
satnogs-3677 | Allocating 15 zero-copy buffers
satnogs-3677 | cb transfer status: 2, canceling...
satnogs-3677 | netrigctl_close: done
satnogs-3677 | Resetting device...
satnogs-3677 | INFO satnogsclient.radio.grsat Stopped gr_satellites
satnogs-3677 | INFO satnogsclient.radio.grsat Processing kiss file
satnogs-3677 | INFO satnogsclient.radio.grsat Total frames: 0
satnogs-3677 | INFO satnogsclient.observer.observer Observation 15105148 finished.
satnogs-3677 | INFO satnogsclient.observer.observer Executing post-observation script.
satnogs-3677 | INFO: 15105148, Norad: 25544, Sat: 0 ISS (ZARYA), Baud: None, TLE: {"tle0": "0 ISS (ZARYA)", "tle1": "1 25544U 98067A 26274.82022115 .00003852 00000-0 78825-4 0 9994", "tle2": "2 25544 51.6316 132.3693 0006938 211.2109 148.8469 15.48706258588280"}
satnogs-3677 | ERROR satnogsclient.observer.observer Waterfall data array is empty
bali
October 2, 2026, 1:47pm
8
very strong signal in 0.0°
4 oktober 1957
sputnik - 1 . thank you sputnik! huray i got the rare sstv card
kc1oca
October 2, 2026, 9:22pm
10
Yours came in nice! Same image but over FN32.
bali
October 3, 2026, 7:03am
12
2026-10-02 23:32 UTC over
stefanp
October 3, 2026, 11:42am
14
How do you get this high resolution? Mine are always lower resolution, even though they are not noisy at all. I took the audio from a satnogs-observation - mybe this is a little lossy compared to a direct SDR-recording?
Stefan / OE6ISP
dl7ndr
October 3, 2026, 1:03pm
15
Hi Stefan,
It’s from a SDR recording, decoded by RX-SSTV.
To check if it’s the SatNOGS observation quality or your program settings, just run my recording through your RX-SSTV.
2026-10-03 10:41 ISS Series 33 - # 9 of 12 - DL7NDR.mp3.zip (624.4 KB)
Daniel
Mny thx Daniel - obviousely the satnogs-audios are lower bandwith or something. I have checked audios from different stations, always the same result.Yours decodes clearly, so I need to check with a SDR recording.
Stefan
2e0gkw
October 3, 2026, 2:58pm
18
Super fast turnaround. Got my ARISS diploma less than 24hrs after submitting captures to the gallery.
Much better with the LimeSDR - even though I forgot to start the rotor
Interesting - the audio-spectrum looks completely different for SDR and SatNogs audio
