It looks like that both Thybolts are alive in CW frequency, however they are ~5-10KHz off.
https://network.satnogs.org/observations/6796187/
EDIT: Here is a better waterfall SatNOGS Network - Observation 6796220
EDIT2: Nothing heard on FSK frequency
Drift for CW transmitters has been added:
Randomly chosen:
-5.7 KHz for Thybolt 1
-8 KHz for Thybolt 2
Scheduled observations in Network have been updated accordingly!
Thank you, @fredy. I saw your observations. FSK Telemetry is only active over India AFAIK.
Based on the TLE shared and temporary NoradID’s in the SatNOGS db I created the following preliminary TLE.
INS-2B
1 99288U 22330.34726505 -.00000000 00000-0 -00000-0 0 01116
2 99288 97.5631 65.2609 0010969 257.1226 307.6549 15.18801812111111
THYBOLT-2
1 99289U 22330.34726505 -.00000000 00000-0 -00000-0 0 01117
2 99289 97.5631 65.2609 0010969 257.1226 307.6549 15.18801812111112
THYBOLT-1
1 99290U 22330.34726505 -.00000000 00000-0 -00000-0 0 01119
2 99290 97.5631 65.2609 0010919 257.3986 307.3787 15.18818263111113
Both Thybolt-1 and Thybolt-2 have been received.
New TLE set in TBA status from space-track.org:
0 TBA - TO BE ASSIGNED
1 54361U 22158A 22330.54007610 -.00000043 00000-0 00000+0 0 9997
2 54361 98.3532 65.3310 0010752 232.2473 249.1355 14.45854148 33
1 54362U 22158B 22330.46716434 -.00000068 00000-0 00000+0 0 9997
2 54362 97.4620 65.8199 0021619 250.9105 248.1914 15.16622961 18
1 54363U 22158C 22330.53211888 -.00000068 00000-0 00000+0 0 9999
2 54363 97.4250 65.7777 0016051 242.8135 252.3438 15.18483425 27
1 54364U 22158D 22330.53159181 -.00000068 00000-0 00000+0 0 9997
2 54364 97.4394 65.7463 0009820 258.0579 234.3284 15.18922767 22
1 54365U 22158E 22330.53148774 -.00000069 00000-0 00000+0 0 9995
2 54365 97.4293 65.7560 0020815 231.6815 260.4317 15.18830380 22
1 54366U 22158F 22330.53127238 -.00000069 00000-0 00000+0 0 9998
2 54366 97.4589 65.7283 0011737 249.0791 242.0276 15.19791103 22
1 54367U 22158G 22330.53189645 -.00000069 00000-0 00000+0 0 9999
2 54367 97.3925 65.8279 0018247 241.5061 253.1743 15.19923954 14
1 54368U 22158H 22330.53271213 -.00000080 00000-0 00000+0 0 9996
2 54368 97.4452 65.7464 0040566 272.9426 226.4454 15.27934667 23
Several are close to our observations for Thybolts so I’ve chosen the following to follow for now:
Thybolt-1 54364
Thybolt-2 54365
INS-2B 54366
@fredy, since FSK telemetry is only active over India does it make sense to set the 436.175 MHz - Data and telemetry transmitter to inactive?
If it is active then let’s keep it as it is. We just need to schedule observations only above India for the FSK. cc @ENSFNM as it seems that scheduled a lot of observations with FSK.
By the way from the latest published TLE by space-track.org for this launch:
0 OBJECT A
1 54361U 22158A 22332.80050388 -.00000043 00000-0 00000+0 0 9998
2 54361 98.3536 67.5569 0011053 222.5849 137.4479 14.45831397 364
0 OBJECT B
1 54362U 22158B 22332.83721204 -.00000068 00000-0 00000+0 0 9991
2 54362 97.4614 68.1551 0022642 240.0506 231.3845 15.16678270 371
0 OBJECT C
1 54363U 22158C 22333.15098119 -.00000068 00000-0 00000+0 0 9990
2 54363 97.4472 68.3231 0010194 257.5293 150.0626 15.19076005 427
0 OBJECT D
1 54364U 22158D 22332.77539015 -.00000068 00000-0 00000+0 0 9993
2 54364 97.4503 67.9487 0010124 253.0646 261.9078 15.19079941 365
0 OBJECT E
1 54365U 22158E 22332.77518431 -.00000068 00000-0 00000+0 0 9993
2 54365 97.4446 67.9442 0010704 259.7824 256.2099 15.19322959 368
0 OBJECT F
1 54366U 22158F 22333.14969117 -.00000068 00000-0 00000+0 0 9997
2 54366 97.4421 68.3113 0009420 260.0174 145.3504 15.19552246 428
0 OBJECT G
1 54367U 22158G 22332.69893324 -.00000068 00000-0 00000+0 0 9993
2 54367 97.4459 67.8792 0007456 259.5868 205.2296 15.19988175 346
0 OBJECT H
1 54368U 22158H 22333.21182008 -.00000069 00000-0 00000+0 0 9994
2 54368 97.4493 68.3888 0007539 268.3451 122.0935 15.20078951 435
1 54369U 22158J 22332.83849855 -.00000069 00000-0 00000+0 0 9992
2 54369 97.4476 68.0191 0007452 274.9326 234.9922 15.20200718 379
1 54370U 22158K 22333.21039666 -.00000069 00000-0 00000+0 0 9998
2 54370 97.4494 68.3872 0007946 278.2432 107.2683 15.20355707 435
Thybolts fit 54363 and 54364, we will need some more separation to identify which Thybolt is which.
Sounds good wrt FSK transmitter. Agree that 54363 and 54364 fit Thybolt well and I believe the Dhruva Space team is also using the same.
THYBOLT 1
1 54363U 22158C 22334.75121328 .00009999 00000+0 47834-3 0 9996
2 54363 97.4491 69.9002 0010504 244.8689 268.5744 15.19133779 668
THYBOLT 2
1 54364U 22158D 22334.75115478 .00010141 00000+0 48490-3 0 9996
2 54364 97.4499 69.8986 0010567 242.9993 270.2786 15.19144054 667
Celestrak TLE for both satellites.
Thanks for the TLE @deepak26, these are the objects we follow in DB and Network for Thybolts. For identification maybe we will need some more time to make sure which Thybolt is which object. If you already have data for the identification please share it.
By the way as informed by @deepak26 the FSK transmission is now on for testing globally, so I’ve scheduled a couple of observations for the next 48h.
Also we have added a new transmitter (uncoordinated one) for INS-2B which probably is OBJECT E(54365).
Sharing the mission link
https://www.dhruvaspace.com/dhruva-space-thybolt-mission-ham-radio-operators
Please report the receptions in the form on the mission webpage for the QSL Card.
Thank You
73Deepak
The INS-2B signal on 435.080 is weak and difficult to get enough SNR, for now I am trying to decode the signal similar to INS-2TD FSK 1200 AX.25.
If there is more information available, then please share it.
Regarding the APRS on 145.850, is there already some scheduling known?
Identifications of the three satellites:
| Satellite Id | Satellite | Identified NORAD ID | Link to Identification Evidence |
| WQPT-3457-5126-1772-6682 | THYBOLT-1 | 54363 | Ikhnos Identification of Thybolt-1 : SatNOGS Community : Free Download, Borrow, and Streaming : Internet Archive |
| FBWZ-9594-5872-5644-3969 | THYBOLT-2 | 54364 | Ikhnos Identification of Thybolt-2 : SatNOGS Community : Free Download, Borrow, and Streaming : Internet Archive |
| EFIC-2341-1789-8177-9840 | INS-2B | 54365 | Ikhnos Identification of INS-2B : SatNOGS Community : Free Download, Borrow, and Streaming : Internet Archive |
Hello! @fredy @PE0SAT @vu2lbw @vu2cwp @DK3WN
We have uploaded our gr_thybolt decoder to GitHub and also an online decoder on our mission webpage.
You can book maximum passes for thybolt_1 and upload your observations and TLM to the webpage
Link to gr-thybolt : GitHub - thybolt4hams/gr-thybolt
Link to online decoder software : thyboltmission.web.app
Dhruva Space | Thybolt Mission for HAMS
ThankYou
73Deepak
Thank you very much for this information,
I immediately wanted to give it try but ran into a problem, please have a look at this issue.
