ISAR Spectrum - Andøya - 2026-09-05 20:12 UTC
TLE Update based on space-track.org catalogue, changed to use temporary NORAD IDs from DB until we complete the support of NORAD IDs > 99999:
0 OBJECT A
1 99416U 26203A   26302.17276099  .00002117  00000-0  15708-3 0  9991
2 99416  97.4110  15.2023 0058542  96.3753 264.4144 15.02732407  8018
0 OBJECT B
1 98914U 26203B   26302.63950573  .00001759  00000-0  13141-3 0  9990
2 98914  97.4100  15.6459 0058573  94.6488 266.1431 15.02686308  8089
0 PLATFORM-6
1 98405U 26203C   26302.63853844  .00001887  00000-0  14060-3 0  9991
2 98405  97.4092  15.6417 0058740  94.4968 266.2971 15.02701838  8081
0 TRISAT-S
1 98406U 26203D   26302.63831642  .00001172  00000-0  89108-4 0  9997
2 98406  97.4101  15.6450 0058374  94.4981 266.2916 15.02667706  8082
0 OBJECT E
1 98528U 26203E   26302.63620088  .00002197  00000-0  16272-3 0  9991
2 98528  97.4103  15.6475 0058242  94.5160 266.2722 15.02778226  8085
Note 1: Some of the above used TLE are not necessarily mean identification for the satellites. Be careful!
Note 2: If something is missed or changed, let me know to fix it
Requested by the SpaceTeamSat1 team, Dwingeloo just observed a pass (H-pol observation, V-pol observation) of the TLE assigned to SpaceTeamSat1, and heard exactly nothing. This means that either the satellite is not transmitting, or it is not Object A. @fredy I suggest re-assigning SpaceTeamSat1 to one of the other free objects (B or E?) so Dwingeloo can have another look there.
@tammojan thanks for the update!
OBJECT B can be identified as FRAMSAT-1, so we should exclude it from the candidates.
Then we have CyBEEsat and SpaceTeamSat-1. The last observation (from the vetted ones) that has signal from CyBEEsat was performed in 2026-10-09, with ikhnos analysis it fits OBJECT E however I would like to check some more recent observations to finalize the identification, as I’m not 100% sure, given that CyBEEsat is not transmitting regularly.
So, I’m almost sure that OBJECT A is SpaceTeamSat1, but I’m going to make it sure by continue my analysis on CyBEEsat.
0 OBJECT A
1 99416U 26203A   26305.76845563  .00003142  00000-0  23090-3 0  9999
2 99416  97.4100  18.6397 0058314  84.3557 276.4315 15.02752815  8551
0 OBJECT B
1 98914U 26203B   26305.70260387  .00002598  00000-0  19194-3 0  9994
2 98914  97.4099  18.5748 0058355  84.4469 276.3408 15.02700919  8546
0 PLATFORM-6
1 98405U 26203C   26305.76818870  .00003004  00000-0  22113-3 0  9999
2 98405  97.4093  18.6338 0058478  84.1147 276.6741 15.02719888  8556
0 TRISAT-S
1 98406U 26203D   26305.76804575  .00001703  00000-0  12747-3 0  9993
2 98406  97.4100  18.6373 0058227  84.1182 276.6677 15.02678645  8559
0 OBJECT E
1 98528U 26203E   26305.96544697  .00003177  00000-0  23325-3 0  9997
2 98528  97.4106  18.8316 0058098  83.4293 277.3542 15.02797451  8589
0 OBJECT A
1 99416U 26203A   26307.63286727  .00002951  00000-0  21715-3 0  9997
2 99416  97.4108  20.4227 0058189  78.0774 282.6968 15.02763772  8831
0 OBJECT B
1 98914U 26203B   26307.63366917  .00002475  00000-0  18307-3 0  9993
2 98914  97.4103  20.4213 0058230  77.9782 282.7962 15.02710419  8832
0 PLATFORM-6
1 98405U 26203C   26307.63264168  .00002761  00000-0  20357-3 0  9999
2 98405  97.4101  20.4168 0058315  77.8575 282.9175 15.02729934  8837
0 TRISAT-S
1 98406U 26203D   26307.63255252  .00001846  00000-0  13780-3 0  9999
2 98406  97.4103  20.4205 0058087  77.9018 282.8708 15.02685457  8833
0 OBJECT E
1 98528U 26203E   26307.23054774  .00002758  00000-0  20303-3 0  9998
2 98528  97.4109  20.0417 0058031  79.2054 281.5697 15.02803809  8778
0 OBJECT A
1 99416U 26203A   26309.89677272  .00003519  00000-0  25796-3 0  9990
2 99416  97.4111  22.5882 0058078  70.5565 290.1924 15.02780165  9176
0 OBJECT B
1 98914U 26203B   26309.89765706  .00003028  00000-0  22289-3 0  9991
2 98914  97.4111  22.5868 0058144  70.4239 290.3251 15.02724420  9170
0 PLATFORM-6
1 98405U 26203C   26309.76342586  .00003505  00000-0  25713-3 0  9994
2 98405  97.4107  22.4545 0058221  70.7286 290.0225 15.02744926  9151
0 TRISAT-S
1 98406U 26203D   26309.96316909  .00002203  00000-0  16354-3 0  9992
2 98406  97.4107  22.6494 0057974  70.1643 290.5819 15.02696620  9186
0 OBJECT E
1 98528U 26203E   26309.69414371  .00003483  00000-0  25514-3 0  9998
2 98528  97.4120  22.3986 0057965  70.9931 289.7563 15.02821285  9146
0 OBJECT A
1 99416U 26203A   26312.16064487  .00007022  00000-0  50986-3 0  9994
2 99416  97.4119  24.7543 0057953  62.9776 297.7350 15.02808946  9514
0 OBJECT B
1 98914U 26203B   26312.62772069  .00005558  00000-0  40520-3 0  9994
2 98914  97.4116  25.1983 0057959  61.3343 299.3693 15.02752556  9585
0 PLATFORM-6
1 98405U 26203C   26312.62662423  .00005811  00000-0  42306-3 0  9997
2 98405  97.4113  25.1934 0058093  61.1860 299.5181 15.02774552  9589
0 TRISAT-S
1 98406U 26203D   26312.16058459  .00003529  00000-0  25921-3 0  9993
2 98406  97.4111  24.7511 0057886  62.7958 297.9151 15.02715226  9513
0 OBJECT E
1 98528U 26203E   26312.75694266  .00005714  00000-0  41530-3 0  9997
2 98528  97.4124  25.3291 0057917  60.7844 299.9157 15.02852694  9600
0 OBJECT A
1 99416U 26203A   26314.95713235  .00005325  00000-0  38751-3 0  9995
2 99416  97.4119  27.4297 0057870  53.6434 307.0112 15.02839408  9930
0 OBJECT B
1 98914U 26203B   26314.95821902  .00004654  00000-0  33983-3 0  9994
2 98914  97.4116  27.4276 0057898  53.5385 307.1157 15.02775315  9936
0 PLATFORM-6
1 98405U 26203C   26314.95708789  .00004817  00000-0  35129-3 0  9991
2 98405  97.4111  27.4228 0058040  53.4353 307.2195 15.02798061  9933
0 TRISAT-S
1 98406U 26203D   26314.95726155  .00003459  00000-0  25411-3 0  9993
2 98406  97.4116  27.4260 0057788  53.5234 307.1297 15.02733071  9934
0 OBJECT E
1 98528U 26203E   26315.15386659  .00004411  00000-0  32149-3 0  9997
2 98528  97.4125  27.6226 0057873  52.8024 307.8465 15.02875482  9967
0 OBJECT A
1 99416U 26203A   26316.02244556  .00004728  00000-0  34453-3 0  9991
2 99416  97.4119  28.4489 0057848  50.1008 310.5283 15.02849448 10090
0 OBJECT B
1 98914U 26203B   26317.15551463  .00003709  00000-0  27170-3 0  9992
2 98914  97.4114  29.5294 0057825  46.2087 314.3900 15.02792914 10263
0 PLATFORM-6
1 98405U 26203C   26317.15435054  .00003700  00000-0  27086-3 0  9991
2 98405  97.4109  29.5245 0057949  46.0455 314.5530 15.02815423 10264
0 TRISAT-S
1 98406U 26203D   26317.15462244  .00002721  00000-0  20079-3 0  9990
2 98406  97.4115  29.5279 0057727  46.2089 314.3891 15.02745808 10265
0 OBJECT E
1 98528U 26203E   26317.15127591  .00003563  00000-0  26046-3 0  9993
2 98528  97.4125  29.5337 0057805  46.1878 314.4107 15.02891169 10261
