I have a question re doppler shifting. Currently gr-gpredict-doppler recommends bandwidth configuration: signal bandwidth + max possible doppler shift.
I was wondering how can I predict this shift and avoid the situation shown in the graph below:
The formula for Doppler shift is relatively simple, see e.g. the Wikipedia article on Doppler effect. We can assume stationary observer:
f = f_0 × (c / (c + v_sat))
Here f_0 is the nominal frequency and v_sat is the velocity of the satellite with respect to the observer (not the orbital velocity). In predict and gpredict this velocity is called “range rate” and you can see that typical values are between 5-10 km/s, depending on the orbit shape and altitude.
Ah! So satellite should fly with much higher velocity or we should live on Jupiter.
I’m doing some research on current doppler shift calculation algorithms. Found quite interesting issue: https://github.com/brandon-rhodes/pyephem/issues/34 It looks like different algorithms/libraries might calculate doppler differently. Do you think it might worth comparing them? I’m just curious
It’s always a good idea to compare various algorithms. I know for sure that in Gpredict I use many approximations that are sufficient for practical purposes but not necessarily accurate enough for analytical calculations.
