I cannot get my TS-2000 to work with Gpredict in satellite mode
I am close to throwing in the towel. I have packet, APRS, cross band repeat, Skycommand with my TH-d72, etc. working on my TS-2000. But I cannot get it to work with Hamlib/rigctld and Gpredict on a Windows or Linux machine. I have spent a couple of weeks on and off trying everything I have found in the forums and I have extensively quizzed AI. It worked once or twice but not reliably. Seems that I can get the uplink VFO(sub) to track, but not the downlink VFO(main). I have tried everything possible. Does anyone have this combo presently working?
I have Hamlib/rigctld and Gpredict working with my FT-736R in full duplex, on both Windows and Linux, so I understand how the system should work.
73 Dave
maybe some screenshot of your screen, can give some of us better view to understand your problems
I’ve made some good progress since I last posted. Doppler tracking is now working. This is on a Windows 10 desktop with a real 9pin serial port.
My rigctld command line: \hamlib-w32-3.3\bin\rigctld -m 214 -r COM2 -s 19200 -t 4532 -C serial_handshake=Hardware,write_delay=5 -T 127.0.0.1 -v
I reverted to an older hamlib, slowed the baud rate to 19200 and added hardware control with a 5mS write delay.
In the device manager for the com port, I lowered the receive buffer to 14 and transmit buffer all the way to 1. I think 1 is no buffer at all.
Gpredict…pretty standard ts-2000 setup.
I tried so many different things that I saw on different forums and then I quizzed AI. I can’t say for sure exactly what fixed my problems but I would have to say going to an older version of hamlib and slowing things down with hardware control is key. The TS-2000 has to be the proper state when rigctld is launched.
Next task - getting this to work on my Linux laptop. Then on to rotor control.
I would still like to hear from others who have this working and maybe see their configuration for comparison.
My backup is a FT-736R that tracks perfectly with no fuss but the computer only sends data to the radio - the radio doesn’t echo anything back to the computer. A limitation of the early CAT implementation in the 736R.
Thanks, Dave
