How do you edit the Gpredict modules? I have several in which I want to add or remove specific satellites. Also, is it possible to delete an entire module?
Thanks.
Thanks.
In the module menu (upper right corner of the module) you will find both “Configure” and “Delete” items. You can also find more tips in the user manual, see https://github.com/csete/gpredict/releases/download/v2.2/gpredict-user-manual-2.2.pdf
Thank you very much.
