First update: I did a fresh install on a Pi 4 (station 908) and the exact same thing happens. (‘Waiting for waterfall’ (audio and data).
The Pi fails with satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Looking at the posts on this forum, it seems it’s a known issue. I have just rebooted the Pi to see if it resolves it.
I have also just scheduled some more passes on station 702 to see if the same error shows.
I’d rather not have to uninstall from the Linux desktop… waiting for a few passes to see what’s in the logs of both stations.
Second update: After the reboot, #908 returned a waterfall. Very happy to see my VHF station back up and running.
Looking forward to this issue being merged into the current release so we can do an update and have the problem solved.
Station #702 has some errors that I need to follow up:
If it can not claim the device, why does it find the correct R8208T tuner chip?
Why can it not find the waterfall file?
I am assuming the unsupported sample error rate links back to the USB_claim_interface error -6.
Mar 11 20:04:14 satnogs-acer satnogs-client[21582]: Assertion ‘close_nointr(fd) != -EBADF’ failed at …/src/basic/fd-util.c:67, function safe_close(). Aborting.
Mar 11 20:04:17 satnogs-acer satnogs-client[21582]: satnogsclient.observer.observer - ERROR - No waterfall data file found
Mar 11 20:12:25 satnogs-acer satnogs-client[21582]: [INFO] [UHD] linux; GNU C++ version 8.3.0; Boost_106700; UHD_3.15.0.0-4satnogs1
Mar 11 20:12:25 satnogs-acer satnogs-client[21582]: [ERROR] avahi_service_browser_new() failed: Bad state
Mar 11 20:12:25 satnogs-acer satnogs-client[21582]: usb_claim_interface error -6
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: Found Rafael Micro R820T tuner
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: Traceback (most recent call last):
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: File “/usr/bin/satnogs_fsk.py”, line 522, in
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: main()
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: File “/usr/bin/satnogs_fsk.py”, line 505, in main
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: tb = top_block_cls(antenna=options.antenna, baudrate=options.baudrate, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, framing=options.framing, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: File “/usr/bin/satnogs_fsk.py”, line 96, in init
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: tune_args, settings, samp_rate_rx, “fc32”)
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: File “/usr/lib/python3/dist-packages/soapy/soapy_swig.py”, line 166, in make
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
Mar 11 20:12:26 satnogs-acer satnogs-client[21582]: RuntimeError: soapy::source: Unsupported sample rate (2048000.000000). Rate must be in the range [8000.000000, 8000.000000] [16000.000000, 16000.000000] [22050.000000, 22050.000000] [32000.000000, 32000.000000] [44100.000000, 44100.000000] [48000.000000, 48000.000000] [96000.000000, 96000.000000]
Mar 11 20:12:31 satnogs-acer satnogs-client[21582]: satnogsclient.observer.observer - ERROR - No waterfall data file found
