I used the same ones. A few needed to be used in inventive ways. No need to cut them down, they work just as well internally and externally as corner parts. Just remove the grub screws and put them in the other way round. Not quite as neat but perfectly good for our use.
Thanks, I guess using them externally would be the way to go. Was going to do that but was concerned that it might cause issues further on in the build process.
Those small corner brackets might also work, but would be a bit weaker I would imagine.
