ve3nnw
November 3, 2018, 2:39pm
#1
I’ve gotten the git version of gpredict compiled with gpsd support built in but it’s complaining in the log file
“qth_data_update_init: Unsupported gpsd api major version (6)”
I have gpsd 3.17 and it’s working just fine with my gps.
Is this a user fixable problem i.e can I “fool” it into working or is a code change required.
Thanks
Dave - VE3NNW
csete
November 3, 2018, 4:39pm
#2
Sorry, no. It needs code update.
I have same error and fixed this error for libgps 3.17.
Patch is as floowsa.
Satoshi
*** qth-data.c.org 2020-03-04 14:03:02.340545844 +0900
— qth-data.c 2020-03-05 08:56:45.554185002 +0900
*************** gboolean qth_data_update(qth_t * qth, gd
*** 472,477 ****
— 472,532 ----
if (gps_read(qth->gps_data) == 0)
/* handling packet_set inline with
http://gpsd.berlios.de/client-howto.html
if (qth->gps_data->set & PACKET_SET)
if (qth->gps_data->fix.mode >= MODE_2D)
if (qth->lat != qth->gps_data->fix.latitude)
qth->lat = qth->gps_data->fix.latitude;
retval = TRUE;
if (qth->lon != qth->gps_data->fix.longitude)
qth->lon = qth->gps_data->fix.longitude;
retval = TRUE;
if (qth->gps_data->fix.mode == MODE_3D)
if (qth->alt != qth->gps_data->fix.altitude)
qth->alt = qth->gps_data->fix.altitude;
retval = TRUE;
else
if (qth->alt != 0)
qth->alt = 0;
retval = TRUE;
#endif
break;
case 6:
#if GPSD_API_MAJOR_VERSION==6
while (gps_waiting(qth->gps_data, 0) == 1)
/* see comment from above */
/* hopefully not needed but does not hurt anything. */
num_loops++;
if (num_loops > 1000)
retval = FALSE;
break;
if (gps_read(qth->gps_data) > 0)
*************** gboolean qth_data_update_init(qth_t * qt
*** 603,608 ****
— 658,686 ----
g_free(port);
#endif
break;
case 6:
/* open the connection to gpsd and start the stream */
qth->gps_data = g_try_new0(struct gps_data_t, 1);
port = g_strdup_printf("%d", qth->gpsd_port);
if (gps_open(qth->gpsd_server, port, qth->gps_data) == -1)
free(qth->gps_data);
qth->gps_data = NULL;
sat_log_log(SAT_LOG_LEVEL_ERROR,
_("%s: Could not open gpsd at %s:%d"),
__func__, qth->gpsd_server, qth->gpsd_port);
retval = FALSE;
else
(void)gps_stream(qth->gps_data, WATCH_ENABLE, NULL);
retval = TRUE;
g_free(port);
#endif
break;
default:
_("%s: Unsupported gpsd api major version (%d)"),
*************** void qth_data_update_stop(qth_t * qth)
*** 639,648 ****
switch (GPSD_API_MAJOR_VERSION)
case 4:
! gps_close(qth->gps_data);
! break;
case 5:
break;
default:
break;
— 717,735 ----
case 4:
! #if GPSD_API_MAJOR_VERSION==4
! #endif
! break;
case 5:
jebba
March 5, 2020, 11:23pm
#4
If you already have github account (I don’t encourage it), it may be better to open an issue or pull request here: https://github.com/csete/gpredict
No, I do not have github account yet. I will create the account and do it this week end.
But I uploaded “qth-data.c” (need thsi file only) on my web site. Also, I uploaded the executabule binary file (rasbian buster for libgps 3.17).
see
http://www.ariss.jp/software/
Satoshi Yasuda, 7m3tjz
DL4PD
March 7, 2020, 10:06pm
#6
Please use the markdown (MD) code tags when pasting source code. Start a code block with three backtics (`) and end a code block with three of them. Like:
int
main(int argc, char *argv)
return 0;
All the best,
Patrick
SatoshYasudai: I tested your patch on a PI4, it works! Thank You!!
I didn’t see a pull request on github from you, so I created one with your modified file:
csete:master
← LeaseOnLife:master
opened 07:46PM - 15 May 20 UTC
Hopefully that is OK with you!
Thanks again
